Is stm32f4 the right chip?
Re: Is stm32f4 the right chip?
@maxi is teasing with itelma M74.9 which uses at32f435zmt7+L9779?! Well at least that at32f435zmt7 has an English datasheet.
8450086873 8450086874
Niva Legend 2022? Niva Travel 2022?
https://www.arterychip.com/download/DS/DS_AT32F435_437_V2.02-EN.pdf
https://caxapa.ru/1203080.html says that at least two vcc/vss pins are flipped
And another one 396200-3763010-00 S105 105.3763 by soate.ru
https://forum.adact.ru/topic/61301-bu-s105-uaz-buhanka-2022/
https://www.jiuyangongshe.com/a/c0rpjvd2d3
Octopus tour
Don't be shy little leeks
2022-12-13 16:23:04
Items:
Company news: AEC-Q100 certification test of the company's holding subsidiary Zhuhai Jihai Semiconductor's automotive-grade MCU APM32A407VGT7, APM32A407ZGT7, and APM32A103VET7, among which APM32A407ZGT7 and APM32A103VET7 series products have obtained both Grade1 and Grade2 dual-level certificates, and can be used in the ambient temperature range -40°C to 125°C for automotive applications.
Fri Dec 23, 2022 1:46 pm
@dron0gus has published an article on hardware reverse engineering
original RU https://habr.com/ru/post/709392/
google translate EN https://habr-com.translate.goog/ru/post/709392/?_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=wapp
Which sometimes uses Geehy apm32F407VGT7
Which just takes rusEFI firmware and blinks LEDs and connects via USB, as is. Software jump to DFU turns off activity but does not produce USB DFU device.
spi SD and MSD works on Geehy.
Mostly fun but could end up being part of a silly evil plan :)
Fri Jan 26, 2018 10:02 pm
S32K update: not really available yet.
Time flies, they now have S32K3 - automotive, lock step, ARM, GCC
Exactly one huge S32K344-wb eval board is available for order today but mouser promises a few more later this month :)
Exactly one smaller MR-CANHUBK344 again mouser promises more soon.
junior-q
Github Username: junior-q
Post by junior-q »
Wed Sep 14, 2022 8:37 pm
Kperformance wrote:
Wed Sep 14, 2022 8:09 pm
hi forumers!
Wanted to know if there are people still working on the 5V automotive graded MCU's?
People are definitely not making progress on Kinetis and Cypress.
It still builds so firmware is up to date but there are maybe two Kinetis units in existence and maybe zero or one Cypress on this planet.
we started to draw a basic board, useful for a simple setup at m73 engine ... using a 120pin fujitsu-spansion-cypress-infineon chip ... a strange son with many mothers .... a S6E2H44 with 256Kb of flash mem
so we are thinking to put a minimal firmware into this device in order to create a limited but simpler ecu
if you have a port for a Fujitsu/Cypress mcu we can try to build for this device
i do not know the flash mem needed for ruefi project but maybe we can reduce while compiling/porting
junior-q wrote:
Mon Sep 04, 2023 8:27 pm
I have too many questions but this thread is not the right one :)
If you want to continue please start a new thread.
junior-q
Post by junior-q »
Mon Sep 04, 2023 9:06 pm
opsss ... sorry ... now i think to a thread name and ... look how to start a thread ... 8-)
