Tuner Studio Integration
Posted: Wed Dec 04, 2013 8:46 am
by izmirliss
Hello,
I need to help about tuner studio integration. Is there any tutorial that tells how can i communicate with tuner studio step by step. I have got the STM32f4 Discovery board with rusefi, and usb cables are connected to board.
I just need to basics... Thanks in advance...
Re: Tuner Studio Integration
Posted: Wed Dec 04, 2013 11:27 am
Is any of the LEDs blinking? How many USB cables are connected? Have you installed
serial-over-usb driver?
To start using TunerStudio, you have to create a 'New Project', choose 'Custom/browse' and select our
rusefi.ini configuration file.
Which version of the firmware have you compiled?
Posted: Wed Dec 04, 2013 11:36 am
by izmirliss
Blue LED is blinking and two usb cables are connected to computer, i have installed to the serial_over_usb driver (its looks as OK in device manager) and i've load to this compiled version ==>
and i think i'm in fault with rusefi.ini file :S
Posted: Wed Dec 04, 2013 11:42 am
izmirliss wrote:I think i'm in fault with rusefi.ini file :S
Help is on the way!
Please download
firmware_binary.zip - it contains a fresh version of the .hex file and rusefi.ini is now included into this bundle. You are pretty close. When you program the discovery with the new rusefi.hex and create a new tuner studio project with rusefi.ini you should see them connected.
Posted: Wed Dec 04, 2013 11:50 am
by izmirliss
Thank you, i'm thinking to try this night and i'll make you know about advances
Posted: Thu Dec 05, 2013 8:39 am
by izmirliss
Hello friends,
Finally yesterday i've connected to Rusefi without any problem
... And i've got new questions:
1)Is there any firmware version with
Manifold Air Pressure - Rotation Speed Map ?
2)Else can we make a
Manifold Air Pressure - Rotation Speed map with
myfloat getMap (void ) function
http://rusefi.com/docs/html/map_8h.html ?
Thanks for helps...
Posted: Thu Dec 05, 2013 8:52 am
by frig
Its not enough. We need "speed density" algorithm implementation for quality work. But now we need good sensors reading. For example - MAP reading is too simple now, integration sensor calibrations is still in progress.
Posted: Thu Dec 05, 2013 9:27 am
by izmirliss
@frig
I think you are talking about a system that can changes the current map values for optimum values (calculated by a algorithm) am i right?
Posted: Thu Dec 05, 2013 9:47 am
by frig
No. To calculate engine VE using MAP and table we need Speed Density algorithm (try to google). This algorithm considers air temperature and pressure to calculate air density. If we do not do it - on any intake air themperature change we have wrong VE and wrong mixture.
Its not to hard, but at first, i think, we need configarable thermistors, MAP, crank position sensors, and other.
Posted: Thu Dec 05, 2013 12:06 pm
by jedediah_frey
frig wrote:No. To calculate engine VE using MAP and table we need Speed Density algorithm (try to google). This algorithm considers air temperature and pressure to calculate air density. If we do not do it - on any intake air temperature change we have wrong VE and wrong mixture.
Its not to hard, but at first, i think, we need configurable thermistors, MAP, crank position sensors, and other.
P*V=m*Rs*T
m/V=P/(Rs*T)
ρ = P/(Rs*T).
R[specific] (dry air) = 287.058 J/(kg*K)
P and T both have to be in absolute terms. That means adding 101 kPa to P at sea level and 273.15 K to T.
mass of air in the cylinder = cylinder displacement * ρ * VE.
Posted: Thu Dec 05, 2013 12:22 pm
Back to reality of current implementation, what we can do pretty easily and what we should do would be a TS property that would control what is used as a key to existing table lookup.
Right now it's hardcoded to be getMaf() in
https://svn.code.sf.net/p/rusefi/code/trunk/firmware/controllers/algo/fuel_map.c
We need it to use either getMaf or getMap or getTps depending on TS configuration - I have just created
a ticket, anyone capable of basic programming can improve this
by izmirliss
frig wrote:No. To calculate engine VE using MAP and table we need Speed Density algorithm (try to google). This algorithm considers air temperature and pressure to calculate air density. If we do not do it - on any intake air themperature change we have wrong VE and wrong mixture.
Can't we configure to the system with minimum and maximum values of the sensors?
