http://rusefi.com/hardwave/176122-6/ would be our first ECU connector breakout board. This TE connector is used on some Mazdas and Hondas from the 90, and since both of my Fords are Mazdas (fine, they are also Kias) - they use this connector.
www.ebay.com/itm/121122884285 would be one of the places where you can buy the connector.
ECU connectors
ECU connectors
Re: ECU connectors
I have found three more TE ECU connector part numbers. TE tech support people do a great job!
http://rusefi.com/hardwave/963063-2 used by Germans in the 90s,
http://rusefi.com/hardwave/174836-5 used by Nissan in the 90s,
http://rusefi.com/hardwave/368255-2 still used by some Asian brands.
Re: ECU connectors
For those looking for the Festiva ECU plug (two plug) I think this is the right one:
http://www.ebay.com/itm/AMP-76-POSITION-MULTILOCK-HYBRID-I-O-CONNECTOR-FREE-SHIPPING-/121192170682?pt=LH_DefaultDomain_0&hash=item1c379dc4ba
It seems to be the same as the one listed on MSquirt for the Festiva, and you just won't use the whole thing.
http://www.diyautotune.com/diypnp/models.html
Re: ECU connectors
I think this four-section one would work for Festiva, but the three-section one is also totally fine - this one http://www.ebay.com/itm/121122884285skeeters_keeper wrote:For those looking for the Festiva ECU plug (two plug) I think this is the right one:
The outer sections would be the one Festiva/Escort GT/older Miata would use and the smaller middle one would stay unused.
Re: ECU connectors
Even better - I didn't realize the aspire unit had two of the same plugs. Is the wiring within the plugs the same/similar? I've never looked at an aspire schematic.
Re: ECU connectors
The Aspire unit is made by Mitsubishi - it's a totally different unit, so the wiring is totally different. But that's a small detailskeeters_keeper wrote:Even better - I didn't realize the aspire unit had two of the same plugs. Is the wiring within the plugs the same/similar? I've never looked at an aspire schematic.
Re: ECU connectors
I just confirmed that this is also the connector for the EDC15 used in ALH VW TDIs sold in the US between 2000-2003. (I.E. what I need for my 2003 Golf).russian wrote:http://rusefi.com/hardwave/174836-5 used by Nissan in the 90s,
Re: ECU connectors
Sweet! I did not find where to buy the connector new and cheap in low quantity, I am not ready to buy 200 pieces from Chinajedediah_frey wrote:I.E. what I need for my 2003 Golf
Jared has created a KiCad module for this connector but the board is not finished yet (the topic is here on the forum). You can source a used connector in a junk yard - they are used on ~2004 Korean cars and these cars are already in the yards. If you brake the board right at the yard you can get the used connector for under $10.
