work in progress 55 pin connector 963063-2
Soldering skill: yes
Coding skill?: yes
This connector is used in plenty on German cars around late 80s - early 90s.
http://www.te.com/catalog/pn/en/963063-2
https://svn.code.sf.net/p/rusefi/code/t ... connector/
Coding skill?: yes
Re: 55 pin connector 963063-2
This connector is available new:
Coding skill?: yes
@ does it one more time!
@ can you do the 3D trick?
Coding skill?: yes
Just tried the paper test and realized that the connectors I've got from China has a bit different footprints:
On the bright side, both rows of pins look right. On the other side, the rows are a bit closer, and there is that 3rd row of seven groups of three pins which are all connected together - some kind of mega-ground I guess. Also the mounting holes are located differently.
I will later try to find the datasheet for this version of the connector I've got.
Coding skill?: yes
Looks like this connector was used on some Chinese car and that's the reason why you can buy it and the matching wired plug:
http://item.taobao.com/item.htm?spm=a23 ... s=1#detail for about $10 not including shipping
jfive
Post by jfive »
Interested in this. I like that it has the wires all ready too. 55 pins should be enough for any 4cyl.
still can't understand if it is just one piece with wires or two pieces: with wires and with legs to be mounted on board.
btw, what's the estimated shipping cost?
Coding skill?: yes
puff wrote:still can't understand if it is just one piece with wires or two pieces
What part of 板插头线束 M154 55针 do not you understand? :) This is just the plug with the wires, the header is a separate item. At least that's the way I understand it.
I've used engtaobao.com and shipping and service fee has more or less doubles the price.
