[info] rusEfi simulator
It's all about the code!
rusEfi simulator
rusEfi firmware simulator is a way to play with the controller without any hardware! All you need is a Windows computer.
Thank you @ for the screen cast!
http://rusefi.com/wiki/index.php?title=Manual:Software:Simulator
jfive
Re: rusEfi simulator
Post by jfive »
Have you tried the jim stim with one of the units yet?
jfive wrote:Have you tried the jim stim with one of the units yet?
Nope - I simply do not have one :)
this topic is about a simulator, not a stimulator. The simulator is a piece of windows software which you use without any hardware whatsoever.
vincenthw
Post by vincenthw »
hello russian,
i have problem with setting up virtual COM/TCP port. i followed the steps given in your video but LAN status is shown error.
i don't know what i did wrong. can you please check the attached figure and help me out?
thanks and regards,
vincent
Screenshot 2014-10-16 20.48.52.png (57.7 KiB) Viewed 14561 times
vincenthw wrote:i have problem with setting up virtual COM/TCP port.
I wonder if the problem is with the TCP port, the process not running or firewall. I've added some troubleshooting hints into the wiki page
subnet
Post by subnet »
vincenthw wrote:hello russian,
thanks and regards,
vincent
when i was trying to get this working i had some problems as well. it also seems that sometimes it just cuts out after doing something (requiring that you go through the process again) even when telnet is responding, and only a reboot seems to get things back to a usable stage.
so as per instructions i do as follows:
reboot computer (if you've already run it before and are getting this error)
start the simulator (note the com port that you're binding to)
create the com in serial port redirector (com port that you selected in simulator, ip address is localhost, port 29002)
rus084
Post by rus084 »
how i can compile it for linux?
Current makefile uses win32 HAL. You would need to compile it with posix chibios HAL which would require the makefile to detect if you run win32 or Unix
rus084
Post by rus084 »
ok , i will try compile for linux (or maybe just use wine?)
rus084
Post by rus084 »
demo from Chibios for Posix-GCC is compiling (need to install gcc-multilib library)
why i have this errors?
i cledated "include ${CHIBIOS}/os/hal/platforms/Posix/platform.mk" in makefile , else compiler demand windows.h library (but i dont make for windows because i add this include)
komp@komp-desktop:/media/komp/ACCA670ACA66CFDE/Users/админ/code/win32_functional
_tests$ make
Compiling chcore.c
In file included from ../firmware/chibios/os/kernel/include/ch.h:113:0,
                 from ../firmware/chibios/os/ports/GCC/SIMIA32/chcore.c:35:
../firmware/chibios/os/ports/GCC/SIMIA32/chcore.h:239:3: error: ‘fastcall’ attribute ignored [-Werror=attributes]
   __attribute__((fastcall)) void port_switch(Thread *ntp, Thread *otp);
../firmware/chibios/os/ports/GCC/SIMIA32/chcore.h:240:3: error: ‘fastcall’ attribute ignored [-Werror=attributes]
   __attribute__((fastcall)) void port_halt(void);
../firmware/chibios/os/ports/GCC/SIMIA32/chcore.h:242:60: error: ‘cdecl’ attribute ignored [-Werror=attributes]
                                                            void *p);
../firmware/chibios/os/ports/GCC/SIMIA32/chcore.c:75:1: error: ‘fastcall’ attribute ignored [-Werror=attributes]
 void port_halt(void) {
../firmware/chibios/os/ports/GCC/SIMIA32/chcore.c:86:1: error: ‘cdecl’ attribute ignored [-Werror=attributes]
 void _port_thread_start(msg_t (*pf)(void *), void *p) {
cc1: all warnings being treated as errors
make: *** [build/obj/chcore.o] Ошибка 1
Is that a 100% original ChibiOS demo failing for you? this case you have a chance to ask on ChibiOS forum.
You say Posix which sounds unix but folder name is SIMIA32 which sounds windows, unless I am wrong. Is this all right?
As an option try editing some Makefile and say -Wno-error=attributes just to ignore this error
rus084
Post by rus084 »
i can compile ChibiOS_2.6.7/demos/Posix-GCC and it works , demo uses SIMIA32 too .
if i use -Wno-error=attributes , attributes errors are fixed , but i get new errors
../firmware/chibios/os/ports/GCC/SIMIA32/chcore.c:48: Error: operand type mismatch for `push'
So ChibiOS demo compiles fine but rusEfi simulator does not compile on Unix?
You would need to take the unix demo Makefile and change it to compile rusEfi simulator. Then you would need to apply all the changes one by one until you find which part of the Makefile is not right. I doubt anyone would tell you something more specific than "your Makefile is wrong"
rus084
Post by rus084 »
YEAH!!!
root@dmitriy-Aspire-V5-571G:/rusefi/win32_functional_tests# ./build/rusefi_simulator
ChibiOS/RT simulator (Linux)
Full Duplex Channel SD1 listening on port 29001
Full Duplex Channel SD2 listening on port 29002
Shell service started on SD1, SD2
  - Listening for connections on SD1
  - Listening for connections on SD2
Running version:
TODO
Warning: NaN injection pulse
i use root because i compilling in chroot
what fixed:
my system is 64bit , chibios only for 32bit . need "-m32" option for compiler
why we dont use "make -j5" option when compilling ?
on my laptop its 126% faster .
34s when just "make" and 15s when "make -j5"
Thank you @ the same Makefile now works on unix! todo: rename "win32_functional_tests" to "simulator"
rus084
Post by rus084 »
i ported rusefi simulator for arm-linux architecture and run it via chroot in android
chibios port is here https://github.com/rus084/chibios-arm-simulator
russian wrote:todo: rename "win32_functional_tests" to "simulator"
And this is done now.
