As per the recomendation here (http://rusefi.com/wiki/index.php?title=Manual:Hardware:Mazda_PnP#Case_Donor) I got a BPA9 ecu from ebay. $30 bucks shipped, it can be gotten for less.
It required a bit of work with a dremel to make the frankenso board fit, so here it goes:
Some material has to be removed from the area around the securing hole next to the ecu connector.
I also had to shave some material of the edge on the other side of the connector so I would not hit the transistor.
If you have an LCD, you will have to clip the corner of it. It's still well secured with just two bolts.
Finally, i made a hole so my connector could fit. This needs to be cleaned up...
Anyways, now it's a lot easier to connect and disconnect the board from the car. And it's protected.
