This is awesome! I just had a look at known_issues.txt and I see a lot of meaningful improvements over 0.1.
Can't wait to see it in action!
Unbelievable what you guys have accomplished.
35) test pads explicit silkscreen
36) test pads on the back of the board
We have these very handy squares for GND and 5v on the front side of the board. #35 is about saying "GND" and "5v" on the silkscreen, and #36 is about adding same nice squares on the back of the board. Since we have some stuff on the back, sometimes I am playing with a multimeter on the back and would be nice to know where to touch and not risking shortening pads on the 25x2 header.kb1gtt wrote:Added to known_issues.txt will figure out what they mean later on.
37) U601/2/3: hard to see pad #1 label on the silkscreen
38) cap values format inconsistency: C165 is ".1u", C24 C355 C471 C701 are ".1uF" and C104 C211 C291 etc are "0.1uF"
Thank you for your interest! There would be no 1.0 or 2.0 until 2018 probably, but there are the green 0.1 and red 0.2juanj wrote:hi friends, when is 2.0 board for sale? i see that testing nowi want order now. i think to order 1.0 but i prefer wait to release
Lol sorryrussian wrote:Thank you for your interest! There would be no 1.0 or 2.0 until 2018 probably, but there are the green 0.1 and red 0.2juanj wrote:hi friends, when is 2.0 board for sale? i see that testing nowi want order now. i think to order 1.0 but i prefer wait to release
Right now I have exactly one bare board or one kit for sale:
https://www.tindie.com/products/russian/frankenso-02-bare-pcb/
http://www.ebay.com/itm/331332410287 same as https://www.tindie.com/products/russian/frankenso-02-diy-kit-/
I am hoping to have some completely assembled boards hopefully before Xmas.
We do not have a trace or a through hole for HIP9011 CS line. We have our own 5v pull-up probably because we are pulling all SPI lines to +5vChip select for SPI communications (active low with internal pullup)
47) HIP9011 CS line needs to be pulled down, not pulled up
51) CAN_RX line should be connected to PB12, not PD12
I would check whether the HIP9011 can live with the CS line pulled hard to the low level. I have come across some SPI devices which need the CS to be toggled as it can leave the SPI slave part of the chip in an unexpected state. So I would always connected it to a GPIO.russian wrote:Re: HIP9011
I think HIP9011 deserves it's own SPI bus to eliminate conflict with any other SPI device, so we would need to simply pull this pin down so that it's always active - no need for a real CS line.
Where would you check that?DaWaN wrote:I would check whether the HIP9011 can live with the CS line pulled hard to the low level. I have come across some SPI devices which need the CS to be toggled as it can leave the SPI slave part of the chip in an unexpected state. So I would always connected it to a GPIO.
50) HIP9011 CS should be connected some GPIO pin, PD11 would work
55) knock1 is actually knock2 and vice versa. Need to fix net names & the pinout picture
There is an opinion that we have placed these USB connectors too far from the edge of the board and this actually causes poor mechanical connection, @ had to grind his cable a bit to work around this. I guess notching the PCB would be another option to resolve this?) place USB connectors closer to board edge or notch the board
) W1002 - silksceen on the wrong place? remove these jumpers anyway?
) 1K and 0R on the MAX9926 input: need to put a comment on the schematics page explaining that none or just one of them should be installed depending on the use-case
dev console/microUSB connection dies
on a real engine dev console sometimes disconnects and can not connect back - looks like an issue more with the port then with the console. this does not happen on a bench
There are reports that multiple rpm hard limit events kill even the USB/TTL port with some certaintyrussian wrote:https://sourceforge.net/p/rusefi/tickets/184/dev console/microUSB connection dies
Order placed! Looks like there would be a ~$40 bump in the price. Time to test http://rusefi.com/forum/viewtopic.php?f=4&t=577 this would shave about $20 off the price.russian wrote:Starting to place an order for frankenso_rev00.40 ETA mid-June.
