[rusEfi] Two stroke Efi (#14)
Re: Two stroke Efi (#14)
Very nice, very nice. Congratulations.
Number-One
Need calibrate my map sensor. How can i get the specs of it? There's a easy way?
MAP is usually linear, u need two points. Weather report would tell u your atmo pressure, about 100 kpa. Then you need another point with some vacuum.
Number-One
100kpa @ stoped engine and maybe 50kpa @ 10k rpm?
Some times you can use a hand pump or hand vacuum pump, connected with a gauge. A bike pump and compression gauge might work.
Number-One
Andrey , please take a look on this vídeo and compare the 2 tps gauges.
https://dl.dropboxusercontent.com/u/33323872/Recording%20%231.mp4
Looks like your TPS settins are not set yet? rusEfi does not know which voltage means 0% and which means 100%Number-One wrote:Andrey , please take a look on this vídeo and compare the 2 tps gauges.
TunerStudio 'Tools->Calibrate TPS' could help, or you can just do the same thing manually - tell me your 0% and 100% 'adc' value
Number-One
Tps is calibrated, you can see the diference on the 2 gauges, tps position and adc tps adc, tps position jumps from 0 to 100%.
one gauge is showing TPS voltage (tps adc, 0-1023)
another gauge shows TPS position (0-100%)
what are your TPS calibration values?
Number-One
closed 43
opened 300
opened 300
can you please do
tpsinfo
in rsuEfi console a couple of times at different adc values and post the output?
tpsinfo
Number-One
2015-05-11 21_59: CommandQueue: SerialIO started
2015-05-11 21_59: SerialManager: Opening port: COM6
2015-05-11 21_59: EngineState: confirmation_~:1
2015-05-11 21_59: EngineState: switching to binary protocol
2015-05-11 21_59: PortHolder: Sending [get_bit 1496 5]
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=0 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=256 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=512 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=768 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=1024 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=1280 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=1536 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=1792 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=2048 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=2304 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=2560 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=2816 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=3072 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=3328 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=3584 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=3840 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=4096 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=4352 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=4608 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=4864 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=5120 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=5376 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=5632 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=5888 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=6144 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=6400 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=6656 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=6912 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=7168 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=7424 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=7680 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=7936 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=8192 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=8448 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=8704 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=8960 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=9216 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=9472 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=9728 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=9984 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=10240 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=10496 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=10752 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=11008 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=11264 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=11520 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=11776 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=12032 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=12288 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=12544 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=12800 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=13056 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=13312 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=13568 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=13824 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=14080 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=14336 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=14592 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=14848 size=256
2015-05-11 21_59: EngineState: READ mode=1 page=0 offset=15104 size=184
2015-05-11 21_59: PortHolder: confirmation_get_bit 1496 5
2015-05-11 21_59: EngineState: confirmation_get_bit 1496 5:14
2015-05-11 21_59: EngineState: bit @1496/5 is 1
2015-05-11 21_59: CommandQueue: got valid conf! ~:1
2015-05-11 21_59: EngineState: WARNING: ADC: should not be asking for NONE vbatt
2015-05-11 21_59: CommandQueue: got valid conf! get_bit 1496 5
2015-05-11 21_59: CommandQueue: Took 5 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 1512]
2015-05-11 21_59: PortHolder: confirmation_get_int 1512
2015-05-11 21_59: CommandQueue: got valid conf! get_bit 1496 5:14
2015-05-11 21_59: EngineState: confirmation_get_int 1512:12
2015-05-11 21_59: EngineState: int @1512 is 400
2015-05-11 21_59: CommandQueue: got valid conf! get_int 1512
2015-05-11 21_59: CommandQueue: Took 7 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 1408]
2015-05-11 21_59: PortHolder: confirmation_get_int 1408
2015-05-11 21_59: CommandQueue: got valid conf! get_int 1512:12
2015-05-11 21_59: EngineState: confirmation_get_int 1408:12
2015-05-11 21_59: EngineState: int @1408 is 0
2015-05-11 21_59: CommandQueue: got valid conf! get_int 1408
2015-05-11 21_59: CommandQueue: Took 6 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 532]
2015-05-11 21_59: PortHolder: confirmation_get_int 532
2015-05-11 21_59: CommandQueue: got valid conf! get_int 1408:12
2015-05-11 21_59: EngineState: confirmation_get_int 532:11
2015-05-11 21_59: EngineState: int @532 is 20
2015-05-11 21_59: CommandQueue: got valid conf! get_int 532
2015-05-11 21_59: PortHolder: Sending [get_float 568]
2015-05-11 21_59: PortHolder: confirmation_get_float 568
2015-05-11 21_59: EngineState: confirmation_get_float 568:13
2015-05-11 21_59: EngineState: float @568 is 1.00000
2015-05-11 21_59: CommandQueue: got valid conf! get_int 532:11
2015-05-11 21_59: CommandQueue: got valid conf! get_float 568
2015-05-11 21_59: CommandQueue: got valid conf! get_float 568:13
2015-05-11 21_59: CommandQueue: Took 10 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 536]
2015-05-11 21_59: EngineState: confirmation_get_int 536:11
2015-05-11 21_59: EngineState: int @536 is 0
2015-05-11 21_59: PortHolder: confirmation_get_int 536
2015-05-11 21_59: CommandQueue: got valid conf! get_int 536:11
2015-05-11 21_59: CommandQueue: Took 8 attempts
2015-05-11 21_59: PortHolder: Sending [get_int 920]
2015-05-11 21_59: PortHolder: confirmation_get_int 920
2015-05-11 21_59: EngineState: confirmation_get_int 920:11
2015-05-11 21_59: EngineState: int @920 is 5
2015-05-11 21_59: CommandQueue: got valid conf! get_int 920
2015-05-11 21_59: PortHolder: Sending [get_int 924]
2015-05-11 21_59: PortHolder: confirmation_get_int 924
2015-05-11 21_59: CommandQueue: got valid conf! get_int 920:11
2015-05-11 21_59: EngineState: confirmation_get_int 924:11
2015-05-11 21_59: EngineState: int @924 is 38
2015-05-11 21_59: CommandQueue: got valid conf! get_int 924
2015-05-11 21_59: CommandQueue: Took 11 attempts
2015-05-11 21_59: CommandQueue: got valid conf! get_int 924:11
2015-05-11 22_00: PortHolder: Sending [tpsinfo]
2015-05-11 22_00: PortHolder: confirmation_tpsinfo
2015-05-11 22_00: CommandQueue: got valid conf! tpsinfo
2015-05-11 22_00: EngineState: confirmation_tpsinfo:7
2015-05-11 22_00: EngineState: tps min 193/max 43 v=0.23 @PA3
2015-05-11 22_00: EngineState: current 10bit=41 value=0.00 rate=0.00
2015-05-11 22_00: CommandQueue: got valid conf! tpsinfo:7
2015-05-11 22_00: EngineState: WARNING: ADC: should not be asking for NONE vbatt
2015-05-11 22_00: EngineState: tps min 193/max 43 v=0.24 @PA3
2015-05-11 22_00: EngineState: current 10bit=37 value=0.00 rate=0.00
2015-05-11 22_00: CommandQueue: Took 2 attempts
2015-05-11 22_00: EngineState: current 10bit=40 value=0.00 rate=0.00
2015-05-11 22_00: EngineState: tps min 193/max 43 v=0.66 @PA3
2015-05-11 22_00: EngineState: current 10bit=117 value=0.00 rate=0.00
2015-05-11 22_00: EngineState: tps min 193/max 43 v=1.21 @PA3
2015-05-11 22_00: EngineState: current 10bit=208 value=100.00 rate=0.00
2015-05-11 22_00: EngineState: current 10bit=207 value=100.00 rate=0.00
2015-05-11 22_00: EngineState: tps min 193/max 43 v=1.60 @PA3
2015-05-11 22_00: EngineState: current 10bit=273 value=100.00 rate=0.00
2015-05-11 22_00: EngineState: tps min 193/max 43 v=1.69 @PA3
2015-05-11 22_00: EngineState: current 10bit=290 value=100.00 rate=0.00
I think I see the problem on my side, please stay tuned.Number-One wrote: 2015-05-11 22_00: EngineState: tps min 193/max 43 v=0.66 @PA3
Number-One
yes, is sw problem, because on older versions was ok.
Number-One
Need help calibrating my map sensor,
the map gauge only moves a litle bit.
It's possible use this sensor?
Do you have a picture and part number for your map sensor? The best way to calibrate is to find the specs online
Number-One
Can´t find information about this sensor. It´s original from Honda cbf and cbr 125.
Keihin brand.
Keihin brand.
Number-One
measure voltage at open air - check your weather forecast, that would be one point. do you have anything to make & measure vacuum?Number-One wrote:Can´t find information about this sensor. It´s original from Honda cbf and cbr 125.
Keihin brand.
Can you connect to a hand held vacuum pump with gauge? Then measure voltage per gauge reading.
The link to the store for this device showing it costs about $25usd. It is a very common mechanic tool.
Number-One
I know this tool here, but i don´t know if i can find with the gauge, most of people buy without gauge to be cheaper. Need ask tomorow.
Perhaps you can add a gauge with a Tee or similar fittings. The gauge does not need to be connected to the hand pump, it just has to be in the vacuum hose.
Number-One
Russian, need your help
After some research found some bikes and some ford and honda cars with this map signal. I belive i have this signal on my sensor.
It´s possible use this map sensor signal with rusefi?
I would guess that first we would need to convert the frequency into voltage somehow.
@, would it be possible to do that with some magic resistor and cap values on the existing RC filter before the op-amp? I believe right now we have 100R and 0.01uF or something like that.
Number-One
maybe with this
This would not be a simple circuit. 50% duty cycle means it's not just a low pass filter. I played around some with QUCS looking at adding a diode and cap to function as freq to voltage converter. So far no easy solution. I might have something that produces .9V to 1.1V, but that range is blah, and it takes some time to settle out, so it's kind of a crappy solution.
What about an external microcontroller-based DAC? I believe, the simplest solution would be to replace this sensor with another type.
The programmable way would probably require another system timer, which might not be available + some development effort.
However, looking at this sensor, I believe it has some advantages over the analogue sensors: Its readings don't change with temperature; they don't require ADC circuitry; they are probably less prone to EMI, etc.
I see, so I would need to implement the digital signal processing. That could be done.
I've just ordered myself a used Ford sensor, maybe I will have the code in about two weeks.
Number-One
I can do some tests with my sensor if you need.russian wrote:I see, so I would need to implement the digital signal processing. That could be done.
- abecedarian
Did you look at LM2907/LM2917 frequency to voltage converters?kb1gtt wrote:This would not be a simple circuit. 50% duty cycle means it's not just a low pass filter. I played around some with QUCS looking at adding a diode and cap to function as freq to voltage converter. So far no easy solution. I might have something that produces .9V to 1.1V, but that range is blah, and it takes some time to settle out, so it's kind of a crappy solution.
