[rusEfi] Two stroke Efi (#14)
Re: Two stroke Efi (#14)
There are several frequency to voltage converters out there. I have not looked at them closely at all. They would require a PCB layout and would need to be scabbed into the existing PCB's some how. Andrey knows that you can do thing like use a PWM output then low pass filter it to make an DAC, so he inquired if there was a semi easy way to do the same on the ADC with these signals. The problem is that these DAC's use a duty cycle to generate the various voltages, and we have a fixed duty cycle, so a low pass filter no worky for this application. The more elegant solution is to add this to the firmware.
This discussion about frequency MAF and MAP has been continued in this tread http://rusefi.com/forum/viewtopic.php?f=5&t=878
I've added Ford setting decoding into your config, but I guess your Honda sensor calibration is different?
Does your digital multimeter have Hz mode? What does it show at room pressure?
Number-One
I´m not sure, but i think i have 100hz @ idle. I will do some tests tomorow and give feedback.
By the way, how high did you rev your engine with rusEfi?
Number-One
I´m not sure, because i don´t have rev counter. I´m waiting this http://www.aliexpress.com/item/KOSO-original-speedometer-motorcycle-meter-hot-sell-motorcycle-parts-free-shipping/1852297551.html
but i can get 10k easy .
Number-One
Andrey, please check this video. I don´t have a good map value.
https://www.dropbox.com/s/4ef4ahp6jxfzyyt/3.avi?dl=0
Can you help?
Can you help?
Step 1: let's confirm that you are using the right input and firmware. For that, can you please hit 'enable self_stimulaton' while ECU is not on the bike, that would make simulated signal on your pin PD0 I believe (triggerinfo command would confirm trigger simulation pin)Number-One wrote:https://www.dropbox.com/s/4ef4ahp6jxfzyyt/3.avi?dl=0
Once you feed this simulated trigger into MAP input you should get less crazy MAP values.
Step 2: you can try feeding the value via the op-amp, this has helped me with some signals like vehicle speed sensor. Please note that my Ford MAP was producing a clean signal as is, without an op-amp.
Step 3: do you have an oscilloscope or a friend with one? That's the electronics engineering domain here and it requires some tools and knowledge for investigation
Sound card O-Scope would be good enough for this kind of slow signal.
- rus084
do you use frequency output MAP ?
Number-One
I can get a scope, no problem.kb1gtt wrote:Sound card O-Scope would be good enough for this kind of slow signal.
Number-One
Yes.rus084 wrote:do you use frequency output MAP ?
- rus084
do you activated frequency MAP sensor mode ?
Yes, it's in the config - as long as latest firmware & config was reset with set_engine_type 29rus084 wrote:do you activated frequency MAP sensor mode ?
https://svn.code.sf.net/p/rusefi/code/trunk/firmware/config/engines/sachs.cpp
Number-One
yes, on ts i have
map input type
frequency-based map
map input type
frequency-based map
Number-One
Update.
Number-One
Need adjust injection starting point. What´s the command to advance it?
that's offset regardless of engine load and RPM. There is also a tunable table of injection phase by engine load and RPM if you need it.
I've just added this field into Tuner Studio project but that would force you to upgrade to newer version.
// set_injection_offset 0
engineConfiguration->injectionOffset = 0;
is this via microUSB on the discovery or miniUSB on the Frankenstein?[10:01:21 AM] ! ecu Number One Filipe: my problem now is the connection
[10:02:10 AM] ! ecu Number One Filipe: few seconds after start the engine, ts or console loose connection
Number-One
Micro usb on Discovery.
It matches my experience - microUSB is for some reason more fragile comparing with miniUSB on Franken board. Please try using a jumper and moving to miniUSB if you have that section soldered.Number-One wrote:Micro usb on Discovery.
Could be electrical issue, theoretically could be software issue but my bet is on electrical. If only we had an EE with a test mule and enough time...
Tomin
Usb is sensitive to noise unfort. You can try ferite bead on usb cable. To me helps in 60% cases.
Tomas
Thank you for the idea, I will try with a ferrite bead cable!Tomin wrote:Usb is sensitive to noise unfort. You can try ferite bead on usb cable. To me helps in 60% cases.
Number-One
Different types and sizes.
Number-One
Update
Number-One
Idle controller
Number-One
Question about usb ttl option on frank.
With this hardware i don´t need use the 2 usb on discovery? i can use this port for ts and console right? And about pb1 jumper?
fabric can make a shortcut circuit (circuit shorted)
pb1 is not even used now, latest firmware has pretty much same protocol on both ports. The TTL on a Frank board replaces the microUSB on discovery.Number-One wrote:Question about usb ttl option on frank.
