I am using 40-130 degrees ATDC.Rhinoman wrote:What window are you using?
It is mounted to block via factory knock sensor boss (just below the cylinder head between cylinders 2 and 3). It was tightened with a wrench but I have no idea on the actual torque.Rhinoman wrote:How is the knock sensor mounted? it is very important that the mounting surfaces are flat and the sensor is correctly torqued.
I've seen the warnings of resonance from the wiring in several datasheets for knock sensors. However, they do not provide much information in regards to preventing resonance. Would you care to explain how to prevent resonance of the wiring? The knock sensor uses the factory connector and a single conductor Tefzel shielded wire crimped to the appropriate terminal.Rhinoman wrote:In a previous job I used to design this type of sensor and interface circuitry, most of the issues that we had, even on the vibrator, were from the mounting of the sensor; even the weight of the wires can cause a resonance.
Edit:
Also, I am using the factory resonant sensor (not flat response).
