work in progress rusEfi own wide band controller board add-on using CJ125
Our little board for Bosch CJ125
https://github.com/rusefi/rusefi/tree/master/hardware/CJ125_board
ibom available at https://rusefi.com/docs/ibom/
- cj125.png (51.87 KiB) Viewed 17853 times
Re: CJ125 board
Ordered on July 10th 2016.
Re: CJ125 board
The chip is a bit wider than the PCB footprint but I think I made it work for now.
- cj125_rev01.jpg (294.39 KiB) Viewed 17785 times
Re: CJ125 board
This is for wideband o2 controller?
Re: CJ125 board
In the middle of placing an order for the stuff I do not have
1) R10 ,1,117.5,SM0805,,vishay,CRCW080582R5FKEA,DIGI,541-82.5CCT-ND - that's a wrong part number for 117.5, but I use an LSU4.2 so that's not blocking me
2) what are R2 and R7 values and part numbers in case of LSU4.2?
3) R15 R8 ,2,1k,SM0805,,Panasonic,ERA-6AEB102V,DIGI,P1.0KDACT-ND it says wrong part number
4) R2 ,1,21k6,SM0805,,vishay,CRCW080527K0FKEA,DIGI,541-27.0KCCT-ND - 27K? wrong part number?
5) CRCW080561R9FKEA same story
Re: CJ125 board
By default assumes you have an LSU4.9 and by default it has no jumpers, such that you have 31.6k and 200 ohms. However if you have an LSU4.2, the intent was that you install jumpers for W1 and W2. Such that resistances drop to 10k or 82.5ohm.
I see that R10 was the wrong value, as well R2 was not quite proper. I have updated these and committed them.
Re: CJ125 board
Jim wrote: according to the datasheet that the DIAHG have to connected to FET's gate and DIAHD have series with 6.8k resistor and connected to FET's drain; but I think that the schematic is inverted
Re: CJ125 board
2) RESOLVED IN R0.2 Q1 MOSFET is not connected properly.
Re: CJ125 board
Ordered on August 6th 2016.
Items 3 of rusefi cj125 0.2
- Snake____1
Re: CJ125 board
How do you actually control the heating element of the lambda probe? Do you have a temperature reference? I know you can use the Ur output for temperature monitor, and the Ua for lambda signal?
(X) BMW E36 318i M50B50 Turbo (MegaSquirt (KdFI v1.3))
(X) BMW E36 325tds M70B50 (ViPEC V88)
(X) BMW E36 328i M52B28 Turbo (rusEFI PnP @me)
(✓) BMW E36 320i M70B50 (rusEFI project car)
(✓) BMW E46 325Xi M57D30 (daily)
Re: CJ125 board
@abricos says we need a little, just a little more spacing between components?
- cj125_02_b.jpg (683.4 KiB) Viewed 17174 times
- cj125_02_t.jpg (500.73 KiB) Viewed 17174 times
Re: CJ125 board
I do not understand your question. The heater is across pins 3 and 4. Looks like H+ is also the 12V on pin 3. That 12V goes to the heater, which then returns to pin 4. This Pin4 is just like a fuel injector, it pulses the heater to make it get hot.
I guess I could have flipped the connector, such that P4 matched the pin out. Perhaps the schematic is what is not making sense. I'm not following.
Re: CJ125 board
cj125 "heat" = yellow wire y/n?
cj125 UN/VS = black wire y/n?
cj125 IA CalR = green wire y/n?
etc
etc
Re: CJ125 board
kb1gtt wrote:I do not understand your question. The heater is across pins 3 and 4. Looks like H+ is also the 12V on pin 3. That 12V goes to the heater, which then returns to pin 4. This Pin4 is just like a fuel injector, it pulses the heater to make it get hot.
I'm sorry I get bad express their thoughts ))))
I noted in the picture it is correct or not ???
Re: CJ125 board
I've ordered some boards, no stock at present so it could be a while. I'm working away from home for at least the next 3 months so no rush - its a job for the summer.
Re: CJ125 board
@ Vague Results Lab presents
- IMAG2577.jpg (3.25 MiB) Viewed 17038 times
Re: CJ125 board
Sweet, that's a nice setup. That should help us get the chip working well.
Re: CJ125 board
We've spend couple hours with @ and @ but something is not right: heater calibration failed.
MOSFET is getting pretty high, we were expecting voltage to be around 5-7 volts but it was closed to 10v.
Sensor temperature did not really change, mosfet is the only thing getting hot.
Re: CJ125 board
curious to see the spi exchange log (from Logic?)
again then, asuming you powering it from a 12V power supply, this means, you have near 100% duty cycle on your mosfet PWM? (log from Logic would be handy)
If it's near 100%, then you probably have a software bug. If it's not, there's something wrong with hardware.
Re: CJ125 board
Лец ми спик фром май харт ин инглиш
This software works well on my board. I think the error in the other.
I'll try to solder to check this board. soon
P.S. someone can explain R8 and R15? I think they are unnecessary.
Re: CJ125 board
[video][/video]Atomic-dm wrote:Лец ми спик фром май харт ин инглиш
Re: CJ125 board
R8 and r15 are part of a filter (together with capacitors) - I would keep them in place)
Re: CJ125 board
3) DIAHD silkscreen on pad #6 should be DIAHG
- screenshot.png (35.9 KiB) Viewed 17015 times
Re: CJ125 board
according to Product Information there just capacitors (and no resistors)puff wrote:R8 and r15 are part of a filter (together with capacitors) - I would keep them in place)
http://www.bosch-semiconductors.de/media/automotive_electronics/product_information/CJ125_Product_Info.pdf
Re: CJ125 board
I am mistaken! these are not! I have no idea why they are needed. Probably, they are limiting current from the probe?
Re: CJ125 board
С9 must be equal С2 (maybe it does not matter)
Re: CJ125 board
I think the question is for UR (R8) and UA (R15). I forget why those had the 1k resistors. I'm reasonably sure it's a low pass filter / slew rate limiter. I forget where I got those values from. I'm sure it was off a datasheet or example some where, but I forget where.
