After damage my 4rd discovery board i decided repair them. Changed main chip but now can´t connect main board to ts or console.
If i use stm program i can update board and i can upload rusefi firware with sucess. Any ideas? Maybe need do some configuration?
ps: com port is listed on devices.
Discovery repair
Re: Discovery repair
Any LED activity?
Yes, power leds on and blue led flashing.
That's good news. So blue LED is flashing means the firmware if alive. Please erase chip/program again just to be sure you are running full defaults, if everything else is fine microUSB is supposed to be alive.Number-One wrote:blue led flashing.
Your other option is to try USB/TTL port (PC10/PC11) since that's independent hardware.
(not exactly repair - more like modification)
That's an old spreadsheet - I was trying all discovery pins to make sure they would blink an external LED. The red pins are the ones which did not blink for some reason.
PD0
PA15
PC8
PA9
Anyone has time to check what these are used for on discovery and if whatever would be removed from the board easily to make these pins usable for us?
PD0
PA15
PC8
PA9
- screenshot.png (47.64 KiB) Viewed 4857 times
