Firmware developent status
It's all about the code!
stefanst
Post by stefanst »
Anything <=0 should be an error.
And log(x) == x should never be true for any number x.
2017-04-02 01_10: EngineState: FATAL error: Natural logarithm logf() is broken: 18000.00
log(18000.0)==18000.0
mobyfab wrote:You're using softfp in the Makefile, so it's not fully used.
It has to copy register data from regular to FP registers everytime you need FP.
Looks like this natural logarithm issue is caused by switching from softfp to hard. We are not doing something right I guess, rolling that change back for now.
See https://github.com/rusefi/rusefi/issues/375
See original ticket from a while back https://sourceforge.net/p/rusefi/tickets/149/
ChibiOS3 migration is pretty much done, looking for help with last step: anyone to start a real vehicle using http://rusefi.com/temp/test_chibios_3.zip ? Download/uncompress/flash and publish some log file if car runs fine?
My test mule is waiting for new alternator. Looks like alternators do not like to be excited while output wire is not hooked up.
Firmware help needed: https://github.com/rusefi/rusefi/issues/382
that's an effort to migrate from three separate log entry namings in three different places to using the same constants everywhere by means of wider code generation. All the tools are ready, the remaining part is to actually go locate all the names and extract into the common file.
Major change: @ has migrated rusEfi to ChibiOS 3.1
new issue - "integration with TunerStudio: 3.0.20 and 3.0.21 something is broken" - 3.0.20 and 3.0.21 are pretty unuseable with rusEfi. I am emailing EFI Analytics
https://github.com/rusefi/rusefi/issues/403
Latest known good version http://tunerstudio.com/downloads2/TunerStudioMS_Setup_v3.0.18.exe
https://github.com/rusefi/rusefi/issues/403 closed - TS 3.0.22 fixes the issue
Yet another defect reported by @ fixed - https://github.com/rusefi/rusefi/issues/404
TunerStudio 3.0.22 knows rusEFI signature now - in a couple of weeks I will switch from older test signature into proper signature, this would mean everyone would need to migrate to 3.0.22 or newer to use rusEfi with TunerStudio.
Usability progress - version is now displayed in TunerStudio title.
Post by Abricos »
Small jump congratulations ...
https://github.com/rusefi/rusefi/issues/429 is an incompatible protocol change - you would have to use latest console or TS project with latest firmware.
@ has discovered a bug in PID implementation - https://github.com/rusefi/rusefi/issues/435
It's about minValue/maxValue handing which is currently implemented by artifically setting iTerm to a funny value, even while iFactor is zero, which value then stays forever?!
https://github.com/rusefi/rusefi/blob/master/firmware/controllers/math/pid.cpp
* If we have exceeded the ability of the controlled device to hit target, the I factor will keep accumulating and approach infinity.
* Here we limit the I-term #353
if (iTerm > pid->maxValue - (pTerm + dTerm + pid->offset))
iTerm = pid->maxValue - (pTerm + dTerm + pid->offset);
if (iTerm < pid->minValue - (pTerm + dTerm + pid->offset))
iTerm = pid->minValue - (pTerm + dTerm + pid->offset);
and here is a unit test which shows wrong behaviour:
	pidS.pFactor = 1;
	pidS.iFactor = 0;
	pidS.dFactor = 0;
	pidS.offset = 0;
	pidS.minValue = 0;
	pidS.maxValue = 100;
	pidS.period = 1;
	pid.reset();
	assertEqualsM("target=50, input=0", 50, pid.getValue(/*target*/50, /*input*/0));
	assertEqualsM("target=50, input=0 iTerm", 0, pid.iTerm);
	assertEqualsM("target=50, input=70", 0, pid.getValue(/*target*/50, /*input*/70));
	assertEqualsM("target=50, input=70 iTerm", 20, pid.iTerm);
	assertEqualsM("target=50, input=70 #2", 0, pid.getValue(/*target*/50, /*input*/70));
	// WOW, we are getting non-zero iTerm while iFactor is zero?!
	assertEqualsM("target=50, input=70 iTerm #2", 20, pid.iTerm);
	// and now we inherit this iTerm even for cases where targer==input?! NOT RIGHT
	assertEqualsM("target=50, input=50", 20, pid.getValue(/*target*/50, /*input*/50));
	assertEqualsM("target=50, input=50 iTerm", 20, pid.iTerm);
Post by puff »
It's not April's fool, is it? :D
I wanted to add mass storage drivers into the firmware for a while but I though that I've lost the working sample. I've found it!
Would anyone with a MAC try the sample firmware from ARMCM4-STM32F407-DISCOVERY-USB-MASS-STORAGE-SPI.zip from https://github.com/rusefi/rusefi/issues/140? That's without rusEfi but using rusEfi default SD card pinout.
For first step my idea is two use the user button to switch between USB port modes: normal mode serial USB, is reset while holding button it would be mass storage instead.
Theoretically a composite device could be possible but that's above my current USB skills.
I did not realize that TS supports text fields!
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
russian wrote:For first step my idea is two use the user button to switch between USB port modes: normal mode serial USB, is reset while holding button it would be mass storage instead.
I can try implementing composite device. CDC + MSD.
mobyfab
Post by mobyfab »
This might help: https://github.com/fpoussin/MotoLink/blob/master/code/common/usb_config.c
Another week of vacation :)
A lot of life in the way of firmware progress these days.
Post by puff »
!!! congrats!!!
your first kid?
Thank you :)
It's complicated :)
Such a cute little one. Assuming that's yours and not a rental, your going to have allot less time in the near future.
matt
donator
donator
Post by matt »
Congratulations!!
mobyfab
Post by mobyfab »
Congrats!!
Making an incompatible configuration change today - https://github.com/rusefi/rusefi/issues/495
While I am not making too much progress these days, @ and @ are really pushing cold start and idle control forward!
Just migrated to latest stable ChibiOS - see https://github.com/rusefi/rusefi/issues/463
minor issue with it - need to fix https://github.com/rusefi/rusefi/issues/551 but that should be easy
