Eclipse madness
It's all about the code!
NBytevenom
Eclipse madness
Post by NBytevenom »
Hi All,
I have not used eclipse in a while, so please be warned.
I followed all the instructions in this guide http://rusefi.com/forum/viewtopic.php?f=5&t=9
However I still cannot compile within eclipse. I have no problem compiling from console.
I get this error in eclipse
Compiling chcoreasm_v7m.s
make: arm-none-eabi-gcc: Command not found
Compiling crt1.c
ChibiOS3/os/common/ports/ARMCMx/compilers/GCC/rules.mk:226: recipe for target 'build/obj/chcoreasm_v7m.o' failed
make: *** [build/obj/chcoreasm_v7m.o] Error 127
ChibiOS3/os/common/ports/ARMCMx/compilers/GCC/rules.mk:226: recipe for target 'build/obj/crt0_v7m.o' failed
make: *** Waiting for unfinished jobs....
make: *** [build/obj/crt0_v7m.o] Error 127
ChibiOS3/os/common/ports/ARMCMx/compilers/GCC/rules.mk:217: recipe for target 'build/obj/crt1.o' failed
make: *** [build/obj/crt1.o] Error 127
Any idea of a configuration setting that I might have wrong in Eclipse?
Re: Eclipse madness
Did you get a proper validation when you did this step?
Validation: in cmd, type "arm-none-eabi-gcc -v" and you should see "...gcc version ... something"
Re: Eclipse madness
Eclipse cannot find ARM gcc.
Is your ARM gcc in PATH?
Have you restarted Eclipse since installing ARM gcc?
NBytevenom
Re: Eclipse madness
kb1gtt wrote:Did you get a proper validation when you did this step?
Yes I did.
NBytevenom
Re: Eclipse madness
So I changed the PATH variable to path (case change).
Now I have this error: ".dep/hal_usbh_msd.o.d:1: *** multiple target patterns. Stop."
Re: Eclipse madness
Not enough information.
1) please confirm where did you get source code from
2) please confirm how does 'make' work from command line
3) please confirm if you eclipse project file is any different from rusEfi eclipse project file
NBytevenom
Re: Eclipse madness
russian wrote:Not enough information.
1) I used desktop Git to download the repository onto my computer
2) 'make' only works if I'm in the "Gnu Tools Arm" directory
3) The eclipse project file should be the exact one as the one in the Git repository.
Re: Eclipse madness
NBytevenom wrote:'make' only works if I'm in the "Gnu Tools Arm" directory
This is a really bad sign. You have some sort of a path issue. Maybe you have multiple copies of make? Maybe something else? But 'make' from command line while inside firmware folder should compile & link rusefi. No point in trying eclipse until this works.
Maybe 'make clean' once in a while while you change stuff? Maybe post full output of 'make' after 'make clean'?
