[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) Eclipse madness - rusefi.com
Not enough information.
1) please confirm where did you get source code from
2) please confirm how does 'make' work from command line
3) please confirm if you eclipse project file is any different from rusEfi eclipse project file
russian wrote:Not enough information.
1) I used desktop Git to download the repository onto my computer
2) 'make' only works if I'm in the "Gnu Tools Arm" directory
3) The eclipse project file should be the exact one as the one in the Git repository.
NBytevenom wrote:'make' only works if I'm in the "Gnu Tools Arm" directory
This is a really bad sign. You have some sort of a path issue. Maybe you have multiple copies of make? Maybe something else? But 'make' from command line while inside firmware folder should compile & link rusefi. No point in trying eclipse until this works.
Maybe 'make clean' once in a while while you change stuff? Maybe post full output of 'make' after 'make clean'?
