[Success Story] Ford Festiva / Protege / Miata motor (#3)
Re: Ford Festiva / Protege / Miata motor (#3)
tigeryan
Post by tigeryan »
I posted over there, looks like there might be a few questions for you to answer....
Ford Festiva with Mazda Protege Block, Mazda Miata BP4W head and Protege intake w/mods, Ford Escort GT transmission ----- yup, it is a lemon!!! --- fun site https://mixdrinkenjoy.com
hossein
Post by hossein »
I was trying to run another ford festiva - called pride here -, ignition was good but unfortunately injection and all settings about injection were not !
I'd tied to increase/decrease injection flow, injection base time, and other, and nothing has changed.
- I just run TS on my laptop with new installation of Linux. and i copied TS from my working machine.-
So how i can check whats wrong ? i mean what exactly is wrong here .
I'd shared trigger signal with another ecu - original ecu of car - injectors were working.
Is time or something else wrong ?
Thanks.
Can you pull an injector and squirt in a container? Such that you verify your flow. Can you share crank signals with the oen ecu? Such that oem runs like 3 cyl while you tune only one cyl.
tigeryan
Post by tigeryan »
Need to migrate to fresh firmware maybe one day but right now attached is in the car.
this section was generated automatically by ConfigDefinition.jar based on rusefi_config.txt Sat Feb 02 20:30:30 EST 2019
