It's certainly been a while since I promised to update. I got the boards a few weeks after I last posted. I assembled them, they didn't work, and then they got put into a bin and shelved while I try and sort through the rest of my unfinished projects (it didn't work).
So here I am at work, thinking about this project again and where I went wrong and I think I might have it, just looking for confirmation while I don't have hardware in front of me.
I forgot the capacitors for the crystal
I might have been thinking since I grounded the case that there must be caps inside? I looked up the datasheet some more and there definitely aren't, so I'm going to try and bodge some capacitors on
tonight (I should stop making promises I might not keep) and see if I can get SPI communicating.
Gauges are still a low priority because the car is a bare shell at the moment, and will take at least a few months to build back up. Plus it's getting carbs, so I'll either need to make a compatible gauge sender board or to wait until I convert back to EFI.
