1995 MX5 (Miata) VVT. turbo. rusefi VVT controller...
mazdee
Post by mazdee »
Hi all.
I currently run a '95 mx5 turbo with a 2003vvt engine.
it's on Speeduino at the mo and runs well...but I wanted to try rusefi so I'm starting off planning to use it as a VVT controller.
here is my bench test.
- cheap "DIY more" stm 32f407
- Arduino mega running Ardustim (pattern generator for various decoders)
- an opto board for level shifting.
I added a pattern in ardustim 5degress advanced and tested switching between the 2. looks good
mazdee
Re: 1995 MX5 (Miata) VVT. turbo. rusefi VVT controller...
Post by mazdee »
Sweeping RPM test. offset fixed for 0 degrees
triggers look good
next is to connect some real sensors to the car and see what comes out
mazdee
Post by mazdee »
Today, I am trying to sort an exhaust leak and fitting some mk2.5 vvt crank/ cam sensors ready to connect to rusEFI (i currently use a mk1 cas )
I am running a mk1 cas with 24/1 yoshifab wheel, toyota yaris cops, a turbo off a volvo S60, and a mk2.5 vvt engine.
this is engine #3 . i have snapped rods in the 1st and bent rods in the 2nd. oops :D
mazdee wrote:
Tue Feb 13, 2018 3:04 pm
an exhaust leak, some mk2.5 vvt crank/ cam sensors , mk1 cas, 24/1 yoshifab wheel, toyota yaris cops, a turbo off a volvo S60, and a mk2.5 vvt engine.
this is engine #3 .
What could possibly go wrong :?: :roll:
We are here to help once you need help. 24/1 and NB2 VVT should be possible to configure with current flexibiliy.
mazdee
Post by mazdee »
Brilliant thanks Russian!
tried LCD today. need to sort a joystick.( rotary encoder would be cool . only because I have loads in the parts bin) ;)
mazdee
Post by mazdee »
[youtube][/youtube]
tested vvt triggers today.
is it normal for the VVT angle to be unsettled slightly when blipping the throttle?
mazdee wrote:[youtube][/youtube]
Hi ...
I'm a little confused ...
you use RusEFI software ... on speeduino electronics (hardware electronics) ...
why and why !!!!
Sent from my HTC One M9 using Tapatalk
mazdee
Post by mazdee »
I already have a working setup and it's my daily. using rusefi to do VVT, maybe boost and knock too
mazdee
Post by mazdee »
Speedy doesn't do closed loop VVT yet and something like Vvtuner from diyautotune is £200 ... :o
Few degrees here and there on throttle is what I have, I assume does not matter.
