[help needed] UK Mazda MX5 miata NB 1.8'99 - Future Turbo project r0.5 #38
Re: UK Mazda MX5 miata NB 1.8'99 - Future Turbo project r0.5 #38
Congrats. However you put the steering wheel on the wrong side
- RadMx5
Thank you, haha yeah wrong side...
I have a question: Is it actually possible to use MAX9927 with hall sensors? I got slightly confused now... on the wiki page you reccomend op-amps for hall sensors https://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenstein_board
I have changed my trigger wheel to 36/1 and now I get no signal. I'am still using op-amp buffer circuit. When I get some time I will investigate the circuit to check what is actually happening as I still haven't done it.
Guys if you can tell me if MAX9927 can be also used I would prefer this option then.
Any advice?
Any advice?
Yes MAX9927 can be used for hall. Basically you let one side of the input float, it will go to 2.5V. The you install the pull up jumper from the other side, and the hall will short or open, generating a 0V to 5V pulse. Once that pulse crosses the 2.5V threshold of the other input, then the output toggles.
See schematic page 8, top right notes. If you disconnect CRK2+, that pin will float to 2.5V. Then you install W1002, and hopefully the default 1k ohm will provide enough current for your hall sensor. However some halls need 12V, and more mA's, this setup is likely to work as is.
- RadMx5
Finally solved the issue with the OP-AMP circuits. The default values for hall sensor pul-ups appeared to strong, so I have replaced them with 5k resistor.
The low pass filter seems to distort the signal, so I have removed the capacitors. Now I get perfect square waves for both Cam and Crank triggers.
The car is up and running using the 36-1 trigger wheel, cranks a lot better! I will share my tune, and logs soon...
I ended up not using the MAX9927.
Here are my mods to the circuits:
Wow 5mA was to much and you had to back it down to 1mA. Glad to hear you got that figured out. Keep up the good work.
Just another datapoint: We're running 1k resistors as pullups to 5V on the 9927 on several NB engines with no issues.
Check out scoped signals from stock ECU and rusefi here:
https://rusefi.com/forum/viewtopic.php?f=3&t=1095&start=60#p21130
- RadMx5
I have to confess I have some stutter on my 36/1 race car - like once every 30 minutes at the track. I blame the 36/1 wheel since it demands extra presicion, but since it's only once in 30 minutes and there is little hope to reproduce at the garage all I can do is move crank sensor a bit closer to the trigger wheel.
- RadMx5
Here is my log from a quick test drive from last night if you are interested. Later on today will post my tune as well.
That looks pretty good.
No ignition losses, AFRs are reasonable. Your VE table and accel-enrichment need some tuning, but other than that you're looking pretty good.
- RadMx5
Thanks stefanst for checking the log.
Yes, I know my table needs tweaking as well as accel-enrichements as I do get a poor throttle response under load.
I am a little worried about my timing table. So I know you have to retard the ignition timing on boost, but where can I get a reasonable timing map so I can tweak it?
I compared my old timing table to russians table an mine was pretty advanced... or russians pretty retarded.
I have not connected all the pipes for the turbo and throttle body, so no boost for now.
I am very happy with how the car is cranking
Hovewer the idle valve doesn’t seem to work when I crank the engine. After engine is running idle valve seems to work.
I’ll share my tune so you can see what is what. Cheers!
- RadMx5
I have installed the D585 coils tonight and test drove the car on the attached tune. I get some trigger errors again no idea why
Fixed!
To me this looks like it's clearly a problem at the higher RPM's. I suspect you'll find the 1k will help prevent this. It might be good to switch to the 9927. the op-amp is just doing analog. If your hall doesn't make it to 0V, your input will be above 0V. The rounding near the edge corners will be seen by the GPIO and could cause excessive jitter. The 9927 will force 0V when ever the input crosses 2.5V. That makes for a cleaner signal to the STM pin. The STM32 is guaranteed to be a 0 when you are below something like 0.5V or 0.9V. Above that is not guaranteed. The 9927 ensure that below 2.5V is guaranteed to register as a 0V. By guaranteeing that it registers at a much higher voltage, it minimizes jitter issues caused by the rounded corners of the signal.
You could try looking at how square you signal is at the STM32's pin. I'm fairly sure you'll see there is a fair bit of rounding at the corners of your edges. This rounding will become more of an issue at higher RPM's.
- RadMx5
Trigger problem solved!!
Thanks kb1gtt for your advise. To be honest I tried soldering the MAX chip, but I found it soo difficult while all the wire jumpers around are very close to it...
I'm still using op-amps
didn't give up haha
Invert primary signal feature was enabled and messed everything up. rusEFI counted gaps instead of teeth on the 36-1 trigger wheel...
Hopefully now it will be fine, no trigger errors even at or above 7000RPM!
Im happy with it now!
Cranking I can't understand why my Idle valve is not turning on while cranking. I will log some data tommorow and debug IDLE? will this show me some usefull info?
If not how else can I check what's going on with the valve while cranking?
Cranking RPM limit is set to 260 I don't know if it affects it? should it be higher?
Valve frequency: 200Hz seems ok once engine is running.
Once the engine starts valve works fine.
I got some logs from tonight but my debug fields are poinitng at Altenator.
hey! couple of weeks ago I tried starting my 36/1 engine with just VR CPS sensor installed and lm1815-based board serving as a conditioner circuit - I had no time to attach my laptop and looked through the log files just several days later. There was no RPM present in the log file. I just saw it changed to -1 during cranking. First I thought it was a hardware problem (though my diy tacho that used signal from lm1815 board and the same CPS sensor worked just fine last winter). So my guess was the signal was inverted and all I need to get RPM is to rewire my CPS sensor.
I didn't know there was a setting to reverse its polarity.
But now you say that even with reversed polarity it somehow worked with 36/1 trigger wheel? I'm a bit confused
That idle valve behavior during cranking is weird and wrong. Mine doesn't do that. See attached picture. I do seem remember, however, that I had a similar problem a few firmware revisions back. Are you running the latest and greatest?
I noticed that you are using a pretty high value-75. Maybe you're exceeding some limit? Have you tried a lower value- maybe 40?
Here's a log of proper cranking IAC behavior.
- RadMx5
Since my last post I almost daily drive on rusEFI. There are no issues with the electronics, firmware and software, it seems very stable!
The car is turbo charged and runs on over 10 psi boost and... the clutch slips on 3rd gear on full boost
Fuel map and ignition timing need fine tuning on a dyno, one day
I only had a problem with the cheap ebay china 3Bar Map...I have replaced it and now the engine runs good again.
I just wanted to thank you guys for your support here! And I hope this project continues to grow!
alexander-n8hgeg5e
Cool
the clutch slips means engine runs good.
Hey, somebody else who daily drives rusEfi and it made the clutch slip in 3rd! I turned the boost up from 8 to 15 on my Volvo, and it made the clutch slip! Fixed with a more expensive clutch
Cool and good to hear. Thanks for the pat on the back and keep up the good work.
- RadMx5
Hello friends!
Haven't been here for a while
Do I need to catch up a lot?
What is the current status of the rusEFI? I've seen some progress with ETB, is it usable? (it would be nice to add an ETB to the MX5)
What about the hardware did you change something?
Should the latest bundle work on my board?
Sorry for asking many questions, but it is hard to keep track what's going on here if you have a little break hah. I thought I will simply ask here instead of digging 100 topics hah
I still have the car, and the plan is to get the rear suspension cleaned and powder coated
I'll upload some photos later
https://github.com/rusefi/rusefi/blob/master/misc/Strategy_2019.md
only 500 meters on ETB, very little testing. No ETB idle, a lot to develop still.
you would probably need to create new projects but we are always (so far) compatible with all hardware from the past.
I believe yes latest firmware should work with any older pcb's.
It gets harder to keep track of stuff as much of the development conversations are happening in slack. TS has / is undergoing some rearranging. I understand that is a welcomed cleanup.
- RadMx5
Finally welded the diff
Many people help, support and motivate me to get this car back on road/track
It's getting there! Sorry for the mess in the garage haha
No time for cleaning...
Some photos:
Some photos:
This diff is not orange
It's not rusEfi-compatible if it's painted blue
- RadMx5
helloo!
Quick update
Here are some photos:
I need to get new lambda sensor and go to a dyno to tune the fuel/ignition timing tables properly, in mean time repair some little oil leaks and do the body work
Then it should be ready for a track day!
Need new rear discs also...
Quick update
So, rusEFI turned you Miata into a squealer
- RadMx5
hah yeah pretty much...
The car wasn't touched for about 5-4 months while waiting for the rear sub-frame and suspension to be done and it took only a few turns of the crankshaft to start the engine without touching the throttle too, I didn't expect that tbh
