Trigger Wheel Teeth
sparky
Trigger Wheel Teeth
Post by sparky »
I am taking my flywheel to the machinist tomorrow and just want to understand if there are any restrictions on the number of teeth and skip teeth with RusEFI? This is for a single cylinder 2 stroke engine. Since it will be manual machining, the machinist may be restricted by his equipment. so probably 36, 24, 20... at least to the degree.
Re: Trigger Wheel Teeth
36-1 and 60-2 are popular optuons but rusefi can fo any x-y
Tons of teeth can have a little trouble at very high RPM, so 24-1 is probably a safe bet.
