SVN repository
176122-6-connector.zip
Also available at our store
See also https://rusefi.com/wiki/index.php?title ... ors#64_pin
http://www.te.com/global-en/product-174917-7.htmlrussian wrote: One of the pins not sure about the other kind
http://www.mouser.com/search/ProductDet ... ey173634-1
$50 is the threshold. https://www.amazon.com//dp/B078WPT5M1 has positive reviews.
TE 175061 and 173631 as mentioned before.
which Miata uses 76 pin / 4 plug connector?
you're right, NA use 2 or 3 plugs depending on year, then NB1 3 plugs and finallyNB2 use 76pin but its a different shape like you have already done, in 3 rows !
russian wrote: ↑Sat Apr 14, 2018 1:24 pmNew version of the board has arrived - better silkscreen and larger wire holes. https://www.tindie.com/products/russian ... ata-nanb1/
1) RESOLVED IN R0.2 Silk screen was made better.
2) Add same silkscreen to back side.
