See also:
https://github.com/rusefi/ChibiOS/pull/2
https://github.com/rusefi/rusefi/pull/552
2018-12-24 00_22: EngineState: perSecondIrqDuration=39929504 ticks / perSecondIrqCounter=24795
2018-12-24 00_22: EngineState: IRQ CPU utilization 23.767562866%
2018-12-24 00_22: EngineState: perSecondIrqDuration=39016138 ticks / perSecondIrqCounter=24567
2018-12-24 00_22: EngineState: IRQ CPU utilization 23.223890304%
2018-12-24 00_25: EngineState: perSecondIrqDuration=33897366 ticks / perSecondIrqCounter=24380
2018-12-24 00_25: EngineState: IRQ CPU utilization 20.177005767%
2018-12-24 00_26: EngineState: perSecondIrqDuration=42725075 ticks / perSecondIrqCounter=25006
2018-12-24 00_26: EngineState: IRQ CPU utilization 25.431594848%
2018-12-24 00_27: EngineState: perSecondIrqDuration=42571610 ticks / perSecondIrqCounter=25247
2018-12-24 00_27: EngineState: IRQ CPU utilization 25.340244293%
2018-12-24 00_39: EngineState: perSecondIrqDuration=14778874 ticks / perSecondIrqCounter=24172
2018-12-24 00_39: EngineState: IRQ CPU utilization 8.796949386%
2018-12-24 00_55: EngineState: perSecondIrqDuration=7315971 ticks / perSecondIrqCounter=4114
2018-12-24 00_55: EngineState: IRQ CPU utilization 4.354744911%
2018-12-24 16_31: EngineState: perSecondIrqDuration=10680357 ticks / perSecondIrqCounter=3271
2018-12-24 16_31: EngineState: IRQ CPU utilization 6.357355594%
(another run)
2018-12-24 16_43: EngineState: perSecondIrqDuration=10232801 ticks / perSecondIrqCounter=3194
2018-12-24 16_43: EngineState: IRQ CPU utilization 6.090952873%
2018-12-24 16_43: EngineState: efiVector6C 23643
2018-12-24 16_43: EngineState: efiVector108 110504
2018-12-24 16_43: EngineState: efiVector148 2
Next leader is efiVector6C which is STM32_DMA1_CH0_HANDLER - looks like SPI DMI2018-12-24 16_55: EngineState: perSecondIrqDuration=1942961 ticks / perSecondIrqCounter=1591
2018-12-24 16_55: EngineState: IRQ CPU utilization 1.156524419%
2018-12-24 17_00: EngineState: perSecondIrqDuration=1278520 ticks / perSecondIrqCounter=1113
2018-12-24 17_00: EngineState: IRQ CPU utilization 0.761023819%
WOW! That's a $190 8 core CPU from 2017?
[ OK ] pidAutoTune.delayLine (2 ms)
[----------] 2 tests from pidAutoTune (208 ms total)
[----------] 1 test from testCJ125
[ RUN ] testCJ125.todo
[ OK ] testCJ125.todo (0 ms)
[----------] 1 test from testCJ125 (0 ms total)
[----------] Global test environment tear-down
[==========] 3 tests from 2 test cases ran. (210 ms total)
[ PASSED ] 3 tests.
It would be quite a bit easier to read if each "bundle" of changes to implement a feature like this was executed on its own feature branch, then merged with a pull request and squash merge in to master. Even if you're the only one who contributed, submitted the PR, and approved it, it still helps bundle together commits like these to prevent polluting master with a long sequence of identical commit messages.russian wrote: ↑Mon Apr 01, 2019 9:27 pmrusEfi is a stinky legacy code base but made some progress under https://github.com/rusefi/rusefi/issues/725 today - the whole console vs TS, text vs binary is a bit less confusing in the code now. Still a mess but a much smaller mess.
Absolutely, those are all the pros of such an approach. I assume we are both aware of few cons of that approach as well, so I have to balance.
Got amber light of power supply deathrussian wrote: ↑Thu Feb 16, 2017 4:48 amShip date: July 01, 2011 end of warranty July 02, 2015 so https://en.wikipedia.org/wiki/Ohio_Refo ... _for_Women has no use for this one.russian wrote:$71 dell optiplex quad-core i5 desktop plus a smaller SSD drive i have in my random parts bin.
I am reusing state prison junk, what am I doing with my life.
Update: diagnostics LED 1 and 2 indicate system board failure, not power supply failure
Jenkins already installed on new build server and I was able to recover jobs settings from old HDD, just need to figure hour nasty Mailer configuration issue hopefully tomorrow.
