I'm little bit confused with trigger settings..
My engine has 60-2 crank wheel and one toth (eg. hole) on cam.
Crank has VR sensor and Cam has HALL.
It is "standard" 4cyl 4stroke engine, 4 injectors, but 4 ign. coils is planed soon. Now I have wasted module.
I will try to run on Frankenstein board, where I have connected all necessary sensors, 4 injectors and 2 ign outputs on Hi-LOW driver.
Can use FULL SEQUENTIAL mode.
VR CRANK is connected to MAX9926 on PC6 as Secondary.
..and now....
How must be set HALL + Pull-Up on PA8 .. ??
as a "Primary channel" ... or as a "Cam Sync"
and which "Trigger type" is right choice for my trigger wheel .. ??
1+60/2, 60/2 VW, 60/2 ... ??
(how are the differences between them..?? - poor documentations for them)
some attachments included ...
Thanks for any hint ....
