aux temp
Re: aux temp
Looks like this feature is not finished
* todo: finish implementation #332
* offset 2468
ThermistorConf auxTempSensor1;
* offset 2500
ThermistorConf auxTempSensor2;
Re: aux temp
Is it very dificult to do? It's only TS display part or is firmware related ? I guess it should be similar to iat and clt . Anyone willing to help ? I wanted to deploy a fan depending on oil temp
Re: aux temp
I might have implemented it or at least made progress.
You would need latest firmware. I am not ready to add a new dedicated gauge for aux temperature so new https://rusefi.com/s/debugmode = "Aux Temperature" added
aux1 is debugFloat1 and aux2 i debugFlost2, in Celsius
Re: aux temp
oh great tks! but it seems now with full pinout 1/2 and 2/2 that aux temp sensor input setting is missing
Re: aux temp
I do not think it was ever there. Anyway, you should see it in a different dialog
Just added to Full Pinout https://github.com/rusefi/rusefi/commit/89962a85c51d7ef2c0084c8c6f9843c01d229e07
dialog = otherSensorInputs, "Other Sensor Inputs"
field = "aux1 TempSensor ADC input", auxTempSensor1_adcChannel
field = "aux1 Bias Resistor Value", auxTempSensor1_bias_resistor
field = "aux2 TempSensor ADC input", auxTempSensor2_adcChannel
field = "aux2 Bias Resistor Value", auxTempSensor2_bias_resistor
