[rusEfi] Моё Чудо ... VW Passat B4 ABA ... #16
the only changes that I was doing I changed between injector simultaneously or sequential ...
I only have a sensor crankshaft
I don't have a camshaft sensor (he is on engine but i don't use it) ...
new date logs
6.30.2019#2.rar
(1.18 MiB) Downloaded 110 times
picture from the console real time of engine spin
New Bitmap Image (2).bmp (3 MiB) Viewed 5733 times
I am trying to help here. My question is if configuration got corrupted and I am looking for real latest logs and real latest tune. You are free to help me help you or not help me help you :)
russian wrote:
Sun Jul 07, 2019 12:14 am
real latest logs is updated Sun Jul 07, 2019 12:05 am
This is supposed to work funny since you do not have cam sensor but it's supposed to work. Do you want to try un-doing sequential back to simultaneous?
You have cranking coolant multiplier set to zero - this multiples your fuel by zero and you get zero fuel.
You have cranking TPS multiplier set to zero - this multiples your fuel by zero and you get zero fuel.
Please set both curves to "1" if you do not want to use those. Please set to something else if you want your cranking to depend on your CLT.
russian wrote:
Sun Jul 07, 2019 12:32 am
I will check again simultaneous !!!
russian wrote:
Sun Jul 07, 2019 12:37 am
There is now a warning code for this case :)
https://github.com/rusefi/rusefi/commit/1fce0201a55c45f8333883cc95589c701d5723d5
YES
that was the problem
I had a zero there
I changed to one (see photo below )
it started working :mrgreen:
New Bitmap Image (12).bmp (3 MiB) Viewed 5722 times
New Bitmap Image (2).bmp (3 MiB) Viewed 5722 times
to use sequential do i need CAM sensor ?
Abricos wrote:
Sun Jul 07, 2019 2:51 am
You can run sequential without a cam sensor. However, it may inject 360 degrees out of phase. There's a 50/50 chance of it being correct or "wrong". That said, I ran my engine for 5000mi/8000km without a cam sensor and it set to sequential, and I couldn't tell if it started in phase or out of phase.
tl;dr: you can safely set it to sequential
idle control ...
i have cable throttle body ...
but inside (throttle body) there is also electric motor ...
so 2 in one ETB and MTB ...
ETB is for idle control and Cruise control ...
what do you think how will it work ??
p.s.do not listen to what I say on the video :mrgreen:
maybe anyone have extra time to see the date log
and maybe you see what improvements can be made
I am very interested how to tune Injection Phase ???
6.30.2019#2.rar
(1.54 MiB) Downloaded 125 times
date log from drag race
7.20.2019.rar
(2.23 MiB) Downloaded 108 times
Abricos wrote:
Tue Jul 16, 2019 10:16 pm
For engines like ours, injection phase doesn't really matter much. You will probably get slightly better emissions, cold start, and idle smoothness if you inject against a closed valve so the fuel vaporizes fully by the time the valve opens. I was unable to observe any difference on my car playing with the injection phase. The injection phase table indicates the END of injection, in degrees after top dead center. So -360 means that injection will finish just as the intake valve is opening. Set it to -400 and call it good.
So how do you tune it? You need an engine dyno, an ultra-expensive exhaust gas analyzer, and an unbelievable amount of time.
if you want to use your standard cable pedal ! BUT electronic throttle ...U need first
honda acura accelerator pedal position sensor
part number 37971-RCA-A01
honda 2.jpg (66.51 KiB) Viewed 4696 times
Connector 6 pin for Honda Acura Accelerator Pedal Sensor
part number 01020101001347
TPS pinout
Hi
So I added TLE7209-R3 H-brige ...
So I connect 12+ 5+ gnd
I connect Throttle position sensor
So I have questions ...
Where to connect H-brige board signal ?
And where to connect pedal TPS ?
