VVT support for mote than one trigger tooth?
It's all about the code!
Post by 960 »
I have a cam trigger wheel with 4 teeth. 2 short and two long.
Do you have any support for it?
I have all the data/angles etc. I think.
Re: VVT support for mote than one trigger tooth?
How many VVT cams do you have? Can you post some images or diagram of this wheel?
960
Post by 960 »
I have VVT at the intake only.
I'll see if I find a image.
It should generate something like this:
Please clarify if this that's hall or VR
The chart seems to show three signals? The one on top must be crank. What are the other two signals? Which one do we care about here?
960
Post by 960 »
It's hall.
It shows the same signal, I think the bottom one are another cam position?
960
Post by 960 »
This should be the right values I think
http://files.s4wiki.com/docs/Audi_R4-5V_T_132kW_ME7.pdf
Page 798.
Searched: Nockenwellen
960
Post by 960 »
This explained a little better to me.
The flank edges are 720/4 :-)
960
Post by 960 »
Just think I found the reason for two long teeth.
It seems like it is for the ecu to know where "Max deviation" are.
I believe that this is finally done https://github.com/rusefi/rusefi/issues/883
