22mm Manhattan
andreika
donator
donator
Re: 22mm Manhattan
Post by andreika » Mon Dec 31, 2018 9:11 pm
Another option for inter-module connection: pcb edge connectors (like PCI-E):
Less solder joints and less assembly efforts, and still 1.1A current rating per pin, according to the specs...
Examples:
64-pin connector for $0.7: https://www.digikey.com/product-detail/ ... ND/1002341
Or 52-pin TYCO: https://www.digikey.com/product-detail/ ... ND/5431235
Re: 22mm Manhattan
Post by Abricos » Sun Jan 13, 2019 4:50 am
3.0 APPLICABLE DOCUMENTS AND SPECIFICATIONS
3.1 MOLEX DOCUMENTS
SD-45970-001
SD-45971-001
SD-46556-001
SD-46557-001
AS-45970-001
3.2 INDUSTRY DOCUMENTS
IPC-9701
EIA TS-1000
TELCORDIA GR1217
4.0 RATINGS
4.1 CURRENT
2.7 Amps
(Note: current flow restricted to 6 adjacent circuits in a given row)
4.2 VOLTAGE
240 VAC
4.3 TEMPERATURE RANGE:
Operating: -55°C to +125°C
Non-Operating: -55°c to +125°C
4.4 CHARACTERISTIC IMPEDANCE:
100 Ω - differential signal pairs
50 Ω - single ended signals
4.5 DIGITAL BANDWIDTH:
Differential signal pairs: up to 12.5 Gbps
https://www.digikey.com/catalog/en/part ... ries/10977
https://www.digikey.com/product-detail/ ... ND/2038493
https://www.digikey.com/product-detail/ ... ND/2038497
Old Grey
Re: 22mm Manhattan
Post by Old Grey » Mon Feb 04, 2019 5:18 am
I have another DIY ECU, but I made it with a side mount internal adaptor PCB like the one above. I can run factory ECU plug, screw, etc, and probably even the MS Ampseal, without touching the ECU. It's just too versatile and compact to not be the best choice, and can make any unit PnP easily. You can even use the adaptor to directly solder wires to an single external connector that plugs to the OEM loom. Connector to connector, is easier and cheaper than connector to connector to wire to connector to connector.
Now the problems. Mine is a single row THT 90º header, and that makes it rather delicate so you have to plug in carefully. It gets bolted together after connection, so it ends up strong, but any lateral force bends/flexes it up. The other problem, like the pic above, is that there is wasted space in the butt connection. If I was doing it again I would use a std vertical header and and flip the adaptor PCB. This would cut length with the overlap, and still keep the height down. Hell you could put the header in the middle of the ECU PCB and have most of it overlapping, except for the actual plug, to make it even shorter.
I did buy a JAMA edge connector out of an arcade machine, but that has the extra length and extra height problem.
Re: 22mm Manhattan
Post by kb1gtt » Mon Feb 04, 2019 10:33 am
I think what you just said, was make a PCB which fits under or over the W## area of Frankenso. Then solder in a bunch of small header pins to connect it the two together. To help save space, the header pins do need to be in a straight line.
Also a picture is worth a thousand words. Even if it's paint or a picture of a napkin pencil sketch.
Another DIY ECU? Can or did you share it some where? Do you have pictures or similar? It's cool to hear about other efforts.
Old Grey
Re: 22mm Manhattan
Post by Old Grey » Mon Feb 04, 2019 12:44 pm
I don't know if it is too unconventional to flip the adapter and ECU connector, but mine is kind-of like this.
I also don't know if there is extra tall headers.
I was also thinking of a half hole castellated adapter module with the ECU connector, like a HC05 on it's PCB interface, soldered over a cutout on the main PCB. It doesn't add much height, but it does take up main PCB area.
Re: 22mm Manhattan
Post by kb1gtt » Mon Feb 04, 2019 5:26 pm
Small suggestion. You can flip it in the enclosure, so it does not need to flip the harness externally. You can install the connector below the ECU PCB, instead of of top. AKA where it would normally sit, simply elevate it and put the connector below it. There are lots of ways it can be done. I might suggest modeling it in ohshape.com to make sure it all fits up as you might expect. See below slightly modified version of your picture. Also keep in mind typically components are populated on both top and bottom of the PCB. The PCB doesn't really have a top or bottom. It's all just for reference. We do tend to put larger / heavier stuff on one side. The light stuff can stay stuck to the PCB when run through a reflow oven. So we put heavy stuff on one side, such that the MFG populates the light side, then reflows it. Then populates the heavy side and re-reflow's it.
adapter PCB flip-flipped.png (41.01 KiB) Viewed 942 times
This extra tall header can get you started looking for an extra tall header.
https://octopart.com/9-146462-0-te+conn ... 6XS7vxIKAA
Soldering skill: yes
Coding skill?: yes
Re: 22mm Manhattan
Post by AndreyB » Tue Feb 26, 2019 1:04 am
Just ordered https://github.com/rusefi/hw_modular/tr ... EO144_wing at elecrow - will start a thread about it once I have the boards.
Coding skill?: yes
Re: 22mm Manhattan
Post by AndreyB » Mon Mar 04, 2019 11:54 pm
So https://github.com/rusefi/hw_modular is the new home for breakout board following the 22mm Manhattan style.
At the moment I can really used some KiCad help with https://github.com/rusefi/hw_modular/tr ... e_Breakout - please let me know if you have KiCad 4 skills or time to learn or $ to just pay someone to make it.
Coding skill?: yes
Re: 22mm Manhattan
Post by AndreyB » Fri Apr 26, 2019 5:22 am
viewtopic.php?f=4&t=1522 as an example of the base board with viewtopic.php?f=4&t=450&p=32907#p32907 plugged into it is the first implementation of this idea.
960
Coding skill?: yes
Re: 22mm Manhattan
Post by 960 » Sat Apr 27, 2019 7:30 pm
Two more modules for the project done :-)
TLE7209 and TLE8888
Coding skill?: yes
Re: 22mm Manhattan
Post by AndreyB » Fri Nov 29, 2019 6:55 am
Finally moving forward with this approach
Coding skill?: yes
Re: 22mm Manhattan
Post by AndreyB » Fri Nov 29, 2019 7:07 am
Coding skill?: yes
Re: 22mm Manhattan
Post by AndreyB » Fri Nov 29, 2019 7:26 am
TLE7209 tested https://github.com/rusefi/hw_modular/tr ... e_Breakout
It works either with a jumper wire, or with the proper diode properly mounted
Coding skill?: yes
Re: 22mm Manhattan
Post by AndreyB » Wed Jan 08, 2020 5:44 am
Sweet this SPI SD-card module would work here nicely
https://www.aliexpress.com/item/32763223573.html "Mini Data Logger Logging Shield Module Board For Arduino For Raspberry Pi Recorder Shield SD Card 3.3V Regululator"
typos like "Regululator" are no reason to worry right?
