MREAdapter72 pnp Miata MX5 NB2
@kb1gtt has designed a Plug&Play board for NB2 miata, also known as Mk2.5 I believe
Documentation at https://github.com/rusefi/rusefi/wiki/MREAdapter72
Schematics is available at https://raw.githubusercontent.com/wiki/rusefi/rusefi_documentation/Hardware/pnp_microRusEfi_nb2/hw72nb.pdf
As an experiment this adapter board would not be open source hardware at least for now.
Based on https://rusefi.com/forum/viewtopic.php?f=4&t=687
Re: microRusEfi pnp Miata MX5 NB2
TDB
TDB
Got my test mule running for two seconds on this board today! That's a huge success, first spin seems to be functional!
Tomorrow I hope to add MAP sensor wiring to get it properly running
- mre_nb2_apart.jpg (614.13 KiB) Viewed 17653 times
- mre_nb2.jpg (760.98 KiB) Viewed 17653 times
That's great success indeed. Perfect way to not go crazy (or crazier as the case may be) during the shutdown.
Yeah looks great I am checking against my harness.
Some concerns to express
1. the heat around mosfet for 5V, could be a problem
2. if I remember correctly the tach output is 12V, it was not working with 5V (memories from 5 years ago)
3. from https://raw.githubusercontent.com/wiki/rusefi/rusefi_documentation/Hardware/pnp_microRusEfi_nb2/hw72nb.pdf
3.1 D21 and D23 should be on pin 37,38
3.2 12_IGN_KEY on 4S - I have to check the hardware, as on my scheme 4S is not connected, same for 3H
About alternator warring lamp, you are going to control it (on/off) via in PA15 from STM?
microRusEfi jumper needs to be set to +12v high-side, I believe we feed +12v signal into both tach and alternatordexter_lab wrote: ↑Sat Mar 28, 2020 1:39 pm2. if I remember correctly the tach output is 12V, it was not working with 5V (memories from 5 years ago)
4S/3H, there is a difference between 2001 and 2003 cars. See notes at https://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_2003#Starting_.26_power
Re: MREAdapter72 pnp Miata MX5 NB2
Here are some pictures of 0.2
https://github.com/rusefi/rusefi/wiki/Hardware/pnp_microRusEfi_nb2/MREAdapter72_0_2_front.jpg
https://github.com/rusefi/rusefi/wiki/Hardware/pnp_microRusEfi_nb2/MREAdapter72_0_2_back.jpg
- more_silkscreen_please.jpg (112.07 KiB) Viewed 17185 times
silk screen can be added after the fact. How's your painting skills?
https://github.com/rusefi/rusefi/wiki/Miata is the latest page trying to paint the whole picture of Mazda Miata MX-5 Standalone plug and play.
First order! This board goes to MA hopefully there will be a report here
- first_order.jpg (808.91 KiB) Viewed 16080 times
That's how OEM case looks like
- nb2oem_top_cover2.jpg (556.52 KiB) Viewed 15876 times
- nb2oem_top_cover.jpg (790.8 KiB) Viewed 15876 times
- nb2oem_back_cover.jpg (359.89 KiB) Viewed 15876 times
On this board both OEM pressure sensor and external MAP are possible (we made some mistakes on 0.2).
external MAP 5v: pin 4K added into OEM harness, MRE72_0.2 has it
external MAP signal: pin 4U added into OEM harness, MRE72_0.2 has it
external MAP GND: pin 3Z added into OEM harness, MRE_02 work-around: black wire: GND to 3Z
external AFR signal: pin 3L added into OEM harness, MRE_02 work-around: blue wire: top 3L to bottom 2O
MRE_02 work-around - 4H removed
- NB2_0_2_internal_map.jpg (4.6 MiB) Viewed 15817 times
What pin on the main connector are we adding the Pull-down resistor (as seen in the pictures) to and what it the pulldown resistance?
// by the way NB2 MAF internal diameter is about 2.5 inches / 63mm
// 1K pull-down to read current from this MAF
engineConfiguration->mafAdcChannel = EFI_ADC_6; // PA6 W46 <> W46
At some point @mck1117 was planning to look into OEM ECU schematics but I am not sure what was the outcome.
I traced out the OEM ECU, and didn't come up with anything interesting. They just had a 1k pulldown to ground, RC low pass filter, clamp diodes, then a buffer. Exactly the same circuit that we run on all of our ECUs.
