work in progress MREAdapter68 VAG
MREAdapter68 VAG
Re: MREAdapter68 VAG
Same exact plastic case holds two sizes ECU. Looks like ECUs are keyed differently but PCB is the same, just a bit of extra length on the longer one.
Metal case lid bolts directly to 68 pin connector throgh holes in PCB.
Long one is 152mm
Short one is 112mm
I believe we do not need the heat sink alumimum bracket and we do not need these holes.
It would be nice to have the two small holes for the black side plastic sheet mouting.
Post by Abricos »
Version 0.1 arrived
First test results
And that's the board which run the engine
