rusEFI online
rusEFI online
https://rusefi.com/online/ is a way for us to share our tunes.
Some documentation at https://github.com/rusefi/rusefi/wiki/Online
HOWTO_upload_tune
rusEFI Commander is a hardware device based on Raspberry Pi 3 Model B and GeeekPi 5 Inch Touch Screen.
HOWTO_upload_tune
Re: rusEFI online
Please upload your tune to https://rusefi.com/online/
Developers need to understand if anyone uses rusEFI and how. At the moment it's really unclear how many installations are in the wild and what kinds of engines are using what features. Once you upload your tune you would get the cool icon on your profile like I have >>>>>> see >>>>>>>>>>>>
Re: rusEFI online
As of today we have manual tune upload.
Next step is to have automated tune upload from rusEFI console - I am now writng rusEFI code to save tunes in TS format.
Next idea - having an external internet-connected device permanently connected to rusEFI. First I will try to simply use USB, first I will try to use Raspberry PI since it's just a small linux really. Hopefully a useful feature would be to get your tune updates from the internet, without touching your vehicle.
- rusEFI_and_raspberry.jpg (663.62 KiB) Viewed 47751 times
Re: rusEFI online
Looks like a screen is needed, just LEDs and toggle switches would not be convenient. rusEFI console now has a special lightweight mode.
Pictured GeeekPi 5 Inch Capacitive Touch Screen 800x480 HDMI Monitor - $46 on amazon or $30 on aliexpress, I like it! it was easy install and it just works.
- REO_hw_rot90.jpg (939.71 KiB) Viewed 47355 times
Re: rusEFI online
Re: rusEFI online
https://www.miataturbo.net/megasquirt-18/diy-raspberry-pi-racedash-92851/
post #50 has a link to STL files on thingiverse.
https://www.thingiverse.com/thing:3564704
Although it's for 7" screen, the center insert could be modified to accept your 5". And the back plate will fit miata. Creator said he used 30x30cm printer and it barely fit diagonally. It's possible to split it into 2 pieces for a smaller printer but strength fill suffer. Mine's 22x22cm btw
Re: rusEFI online
You want this to replace the stock gauge cluster? Most displays you can buy are not bright enough for a dash. A little bit of sun on them and you can't see anything.AndreyB wrote: ↑Sun Jun 07, 2020 5:49 pmAll I need now is a $200.00 3D PRINTED GAUGE CLUSTER
https://pidashs.com/collections/pidash/
Something like this makes more sense in the center console.
Re: rusEFI online
My bad, my joke was confusing. rusEFI Commander device is absolutely _not_ about displaying gauges - the focus at the moment is on logs upload and tune/firmware updates download. While I probably need a way to mount a touch screen I absolutely _not_ plan to replace the gauge cluster.
Actually still an open question if a screen is needed for this IOT device.
Re: rusEFI online
Yesterday news
Today news - I became an Android developer two hours ago.
- Screenshot_20200624-204711_rusEFI.jpg (98.05 KiB) Viewed 46583 times
Re: rusEFI online
Re: rusEFI online
Attempting to Upload the current version of my tune and the website goes to this error a few secs after pressing "upload".
Fatal error: Uncaught Error: Call to undefined function array_key_first() in /homepages/5/d451478433/htdocs/online/rusefi.php:666 Stack trace: #0 /homepages/5/d451478433/htdocs/online/rusefi.php(578): Rusefi->calcCrc(Object(MSQ)) #1 /homepages/5/d451478433/htdocs/online/db.php(927): Rusefi->calcCrcForTune('<?xml version="...') #2 /homepages/5/d451478433/htdocs/online/rusefi.php(365): DB->findMSQ(Array, -1) #3 /homepages/5/d451478433/htdocs/online/upload.php(207): Rusefi->isTuneAlreadyExists(Array, -1) #4 {main} thrown in /homepages/5/d451478433/htdocs/online/rusefi.php on line 666
- website error.jpg (194.16 KiB) Viewed 46250 times
Re: rusEFI online
Thank you for the error report! https://github.com/rusefi/web_backend/issues/66
Re: rusEFI online
Your welcome.AndreyB wrote: ↑Sat Jul 11, 2020 3:19 pmThank you for the error report! https://github.com/rusefi/web_backend/issues/66
Just tried again and it worked!
Re: rusEFI online
New feature of rusEFI tunerstudio plugin: continues tune auto-upload
(Did you know we have rusEFI TS plugin? - find it inside the bundle, it even comes with autoupdate feature)
Re: rusEFI online
Tuner Studio connection has survived a night Getting closer to recording a demo of remote tuning.
Re: rusEFI online
Progress - I've just downloaded a log from ECU SD card via rusEFI proxy for the first time!
It's ugly and it's slow but it works
Re: rusEFI online
Re: rusEFI online
https://github.com/rusefi/web_backend/issues/185 would hit is when TS decides to migrate from binary log format v1 to binary log format v2.
Re: rusEFI online
Re: rusEFI online
I attempt to upload and I get this error message.
https://github.com/rusefi/rusefi/releases/latest/download/rusefi_bundle_proteus_f7.zip
I originally got the F4 version. That console.exe wanted me to install JRE11. Then it complained about F7, and now F7 provides this error message. This is Win10Pro x64 I did a manual upload, which can be found here.
https://rusefi.com/online/view.php?msq=1536
Bundle was found herehttps://github.com/rusefi/rusefi/releases/latest/download/rusefi_bundle_proteus_f7.zip
