I am going to create a list of popular Aptiv (formerly known as Delphi) connectors since GM sensors are popular in the aftermarket world, at least here in the US. The nice thing about Aptiv connectors is you can buy them on Mouser for just a couple dollars each.
This page is a work in progress, I would like to add photos of each connector and finish the list I have. If you have any requests for GM/Aptiv connectors just ask, I will add it to the list.
Pin seals: 15366021, 15366060. I have these on order and have not confirmed which plugs they fit.
Camshaft sensor: 3 pin
Crankshaft sensor: 3 pin
Injectors (truck style): 2 pin
Body: 15326181 (?)
Secondary lock: (?)
Female pin: 15305174 (?)
Ignition coil (group): 9 pin
Body: 120147938
Secondary lock: 12066304
Locking tab: 12020833
Female pin: 12048074
Ignition coil (Individual):
Intake air temp: 2 pin
Body: 12162197
Female pin: 12089290
Coolant sensor: 2 pin
Body: 12162194
Female pin: Same as IAT
Oil sensor:
Electronic throttle body: 6 pin
Body: 15355297
Secondary lock: 15483798
Female pin: 12191819
Pedal position sensor: 6 pin
Body: 15326829
Secondary lock: 15317363
Female pin: Same as electronic throttle body
Transmission (4l80e): 20 pin
Body: 13595247
Secondary lock: 12160494
Female pin: 15359001 (?)
Another lock: (?)
Transmission VSS:
Same as Coolant sensor
Alternator:
4 Bar Map Sensor:
Sensor: 12643955 ($19 from rockauto)
Body: 15397338 (?)
Female pin: 15345046-L (?)
Here is another good source for GM connectors. https://www.thirdgen.org/forums/ltx-lsx/573725-connector-id-pn-interchanges.html
GM/Aptiv (Delphi) Connectors
SVeilleux9
Re: GM/Aptiv (Delphi) Connectors
this is valuable, thank you!
SVeilleux9
Currently testing with a 4 bar map sensor.
Part number: 12643955
This sensor is only $19 from rockauto, or $27 from amazon. Much cheaper and readily available compared to many other MAP sensors.
According to sloppy mechanics themselves this is the Vout vs PSI response.
https://www.amazon.com/gp/customer-reviews/RI0XQLHEX6WNB/ref=cm_cr_dp_d_rvw_ttl?ie=UTF8&ASIN=B005OV8ZOI
