We're a team of 3 (two studying mechanical engineering, one electric engineering) that is building a reverse-Trike with a 1.8l Toyota 1ZZ-FE engine taken out of a Toyota Avensis. The Trike is built for racing and accelerating fast, thus the name. We have suspension that is adjustable via hydraulics (using the power steering pump) that also adjusts our ride height. We're already at a state where we can drive a bit by making use of the starter motor and now we need to make our engine run.
We have tried using an Arduino Nano before and with a program we wrote ourself we did get the ignition to work but we're not 100% certain up to what speeds that would work reliably, if at all. We then kind of resorted to using the original ECU from a Celica T23, we did buy a cable hardness and the ECU for it but buying the necessary parts to make the actual ECU run would be pretty expensive as well as still restricing us in flexibility.
RusEFI looks perfect though! Our plan is to use the microRusEfi kit, 3D print our own enclosure and connect it to the wiring harness we have now.
Some more info on the engine: The crankshaft and camshaft are both using VR sensors, the throttle valve is mechanical. Our electrical connector to the VVT-i valves is gone. We have a MAF sensor. We do not have an o2 sensor at all. The only information we have on the knock sensor is that it has two pins, no idea on further specifics though.
We have a few questions:
Any idea what kinda of knock sensor that is and will we use it with the microRusEfi board?
Will we be able to use the MAF sensor or do we need something else?
How much cooling for the board is required?
Is it possible (and how much effort is it) to make VVT-i work? Would VVT-i even be worth replacing the electrical connector (30€)?
What kind of o2 sensor should we use?
Any other suggestions where to start, what problems we can expect to come across etc would be very welcome as well
