Hello everyone this is my first post
I have an engine which I would like to run. It is from a 2010 jaguar xfr.
5.0l v8 supercharged
direct fuel injection
dual cam per head with variable cam timing
has a denso ECU and Bosch injectors.
I have the factory car ECU but I don't know if it's enough to make it work. Are you able to modify my current ECU? or else supply a new one to run it? Thank you.
rusEfi is not ready to run your engine. We've made it to the point of clicking single injectors, but no direct injection engine is close to running. We also don't yet support multi vvt, so that wouldn't work either.
Are there older versions of this engine with port injection, from which you could swap on an intake?
I would highly suggest trying to get the factory ECU to behave for now, and try rusEfi later once our GDI support is more mature.
