CAN support
Re: CAN support
And logic analyzer hooked to discovery pins shows activity when I poke ELM327 - this makes me think that we have a firmware issue?
Re: CAN support
Back in 2017 we had
Re: CAN support
Poor wiring was the issue. Two different ELM327 clones were handling poor wiring very differently, both now work once I've hooked female connectors on Frankenso 64 pin connector header.
I've got https://github.com/fr3ts0n/AndrOBD/wiki to work - that's an ODB open source software for Android. We can technically build something on top of it...
neongreen
Re: CAN support
Will this just allow reading of standard SAE1979 PIDs?
1962 Ford Falcon 5.0L V8 / T5
neongreen
Re: CAN support
Well that's pretty cool. What's the update rate? Is it fixed or variable?
Re: CAN support
One day we would need a CAN bus hub
Autosport labs uses M8 https://www.te.com/usa-en/products/connectors/circular-connectors/intersection/m8m12.html?tab=pgp-story for theirs
is that going to be a $200 once it's in the box? who knows.
Re: CAN support
Automation industry seem to love those. Weidmuller 1828620000 would be an example of a 4P 4-pin 4-pole M8 box
Re: CAN support
By far the most poplar is the M12 5 pin, followed by the M12 4 pin. I think you'll find the M8 is small and easily damaged. However if you have a fairly low stress environment, and you have space concerns, the M8 is smaller.
Automate
Re: CAN support
Is this the best place to find a list of the PIDs that are available?
https://github.com/rusefi/rusefi/blob/master/firmware/controllers/can/rusEFI_CAN_verbose.dbc
Re: CAN support
No, this rusEFI custom broadcast has absolutely nothing to do with OBD-II.Automate wrote: ↑Thu Jul 03, 2025 5:57 pmIs this the best place to find a list of the PIDs that are available?
Overall OBD-II quality is not high on the priority list.
Automate
