AndreyB wrote: ↑Thu Jul 02, 2020 11:02 pm
It looks like hardware senses the signals which is great news and the most challenging part!
Now you need to get into software. You need to be looking either at Engine Sniffer in rusEFI console or Composite Logger in TunerStudio. And please publish your tune at rusEFI online.
Since the harness is incomplete, pin assignment is also not complete for things I havent wired. That being said I have wired the crank and cam signals.
Not sure you'd want me uploading a tune until its complete unless you just want to see what I have setup so far.
I'm using RUSEFI console to check for trigger pattern in the Engine Sniffer tab and do things like test the Fuel Pump relay in the Bench Test tab... which works.
Just to be clear the Engine Sniffer within RUSEFI isnt showing trigger events. NO heartbeat there. Board disagrees.
I could post a screenshot of the Engine Sniffer but it would just be a blank graph. It does flash the different and correct pin assignments for cam/crank.
