mini cooper runing proteus
Rafa_bmx
Post by Rafa_bmx »
Hi,
as requested by the Andrey this is the post to try to understand a problem on my ''build'' so to speak...
link for the tune https://rusefi.com/online/view.php?msq=423
link for the video-
Problem...
1- hall sensor on digital 1, takes ages to sync and it is only a 60-2 probably my misinterpretation of the configs, trigger log looks perfect, don't have a print for that but it does look normal.
2- every time i set the 2nd pedal sensor as analog volt 5 the serial connection drops, the error led on the board comes on and i get the error you see on the video.
Rafa_bmx
Re: mini cooper runing proteus
Post by Rafa_bmx »
UPDATE 1
got rock solid rpm now on my indoors test rig
is your crank sensor hall or VR?
can you set "debug mode" setting to "trigger counters" and collect a log of cranking and starting for more info on slow start?
Rafa_bmx
Post by Rafa_bmx »
Mon Feb 08, 2021 4:42 pm
Hi Andrey, as per my last post, the crank problem seems to be solved by playing with the configs, now only trying to understand the problem with the fatal error reported on the video
"I have solved my problem, no need for me to share what was wrong since my focus is on just solving my problems, please help with my other problem"
Rafa_bmx
Post by Rafa_bmx »
Mon Feb 08, 2021 6:45 pm
I have solved my problem, I don't know what solved my problem since I don't understand what the options mean because the wording used is not accessible to a bloody foreigner, non-english speaker like me, i'm also not sure if my problem was solved completely because i didn't see the engine working yet, but I believe that is secondary now....
Please help me with the second problem that is Bricking the ecu... :D :D
Thanks
bill
Post by bill »
if you "bricked " the ecu, just erase and reload
https://rusefi.com/forum/viewtopic.php?f=2&t=1749&start=30
**** FINAL LINUX FIX !!!******
i did get this stm32 cube program to work on ubuntu 18.04
https://www.st.com/en/development-tools/stm32cubeprog.html
i erased the chip and reloaded the firmware, finally!
using this .BIN
https://github.com/rusefi/rusefi/wiki/Download
the Proteus 0.3 and newer (STM32F4)
there is a bug in dfu-util 0.9 on
ubuntu 18.04
and also Raspbian -- newest version
do not use!
apparently in Ubuntu 20.04.... dfu-util works fine
for your information ...
Rafa_bmx
Post by Rafa_bmx »
as requested by Andrey
here is the tune that ''fixed'' or seems to have fixed the trigger problem with Hall sensor
https://rusefi.com/online/view.php?msq=424
Rafa_bmx
Post by Rafa_bmx »
as requested by Matt here are the trigger logs
cheers
