Ford EEC-V 104 Pin Connector
dbh97
- Slack: dbh97
I have created a footprint for the 104-pin AMP connector used in Ford EEC-V PCMs.
I reverse engineered the dimensions manually, so there are no guarantees they are correct, but I printed it on paper and it seems to match up close enough.
Re: Ford EEC-V 104 Pin Connector
Thank you David!
Breakout board available at https://github.com/rusefi/rusefi/tree/master/hardware/Breakout_104pin_EEC-V-Connector
dbh97
- Slack: dbh97
A Kicad 3D render for no good reason:
I have also made a blank full-sized PCB available in the repo:
I've put in a order at DirtyPCBs for the breakout, so it should be in my hands some time in January.
dbh97
- Slack: dbh97
These are the harness-side pins. Does anyone know if these can be purchased anywhere?
wstefan20
- Github Username: wstefan20
This link might be helpful: https://eectuning.org/forums/viewtopic.php?t=21285
dbh97
- Slack: dbh97
Breakouts have arrived. If you want one, let me know.
Looks like I got the mounting hole off by half a hole. It wasn't even used in the OE ECU, so probably not a big deal, but I'll fix it anyhow.
Not intended for use in the case:
SHOf429
Looks like some pins near the outer sides might be inaccessible hiding under the case edges?
Josh
94 Ford Taurus SHO
Frankenso in progress
94 Ford Taurus SHO
dbh97
- Slack: dbh97
dbh97
- Slack: dbh97
Assembled. I just soldered my jumper wires for my Discovery on the backside. In hindsight I should have done 2 holes per connector pin, like most (all?) of the other breakouts were. I was too lazy.
Snug as a bug in a rug
dbh97
- Slack: dbh97
I bought another PCM so I could have another connector, and this one has a different case:
This PCM is from a 1997 Taurus/Sable. The advantage of this case is more room to place PCB components. The disadvantage is that it doesn't have the heatsink for the PCB. Though that brings up the question of whether we'd use them anyway. In my blank board Kicad model, the 'top' of the board is towards them, so in order to use them, you would have to put the connector on the back side of the board instead of the front. Also, some consideration might be needed for the height of the parts. e.g. electrolytic caps
Edit:
On looking closer, this PCB is physically bigger, with no mounting holes that match up.
Edit:
motorhead1991
- Github Username: Motorhead
As requested, here I am posting my findings thus far:
Most EEC-IV cases do not have the heat spreaders along the sides, but the ones with the sheet metal clamshell have small openings around the J3 port. For a tinkerer this is not a problem, but for an end user that doesn't work so well. In addition to this, the EEC-V connector does fit the IV boxes, but the screw holes will need to be slotted or moved.
As for the terminals, the Delphi (LS computer) and AMP superseal 1.0 are compatible with minor modification to the red locking bar.
turbotrana
Can I get hold of a couple of these boards sent to Perth Australia. How much are they?
At the moment cheap mail does not go between US and Australia
David, somehow I do not have these in stock
To be honest I do not remember why.
I would like to improve silkscreen - I would like to mark pinout of the actual connector on the back side, and wire holes pinout on both sides. Also I need to add "104 Ford EEC-V" before I can fabricate those
Not sure if you have time to improve the design but any chance you can label one unit with a sharpie? Or does KiCAD footprint pinout actually match Ford pinout?
@turbotrana can you take a picture and mark which pin is which?
dbh97
- Slack: dbh97
@turbotrana I'll send you one if you pay for the shipping. Not sure how much that would be. If China->AU shipping is comparable to China->US shipping, it might be cheaper for you to get some made. 5 PCBs cost me $44.50 shipped.
There have been two versions. The first version I had made is a 2-layer board, while the second is a 4-layer board with much wider traces. On the second run JLC messed up the fab and didn't drill the mounting holes. It's not designed to be used with the case anyhow, so that's really not too big of an issue, but keep that in mind if you want me to send you some.
@AndreyB The Kicad footprint matches the Ford pin numbers. The connector itself has the 4 outer pins numbered if I recall correctly, which is why I didn't bother with numbering the PCB. I can add numbers to the back.
Yes please? and corresponding wires?
if you are in a lazy mood just number the ones on the edges and like every 5th pin at least? from my experience soldering those the more silk the better. also the whole mirror/flipping much easier to handle if everything is nicely marked
turbotrana
I just read up on Dirtypcbs and see that they would get sent from China so prob best to get from there.
So which files do I send them for the 4 layer board. Is anyone by any chance going to do some update files. Numbering of the pins (eg 0 - 13, 14-26 etc) would be good. Nevertheless credit to you guys. 15 years ago I used to cut up Ford 60pin ecus and solder onto the pins to make harnesses to run aftermarket ECUs. These PCBs make the job a whole lot easier.
Andrey, what do you need a picture of?
This is a pic of a Breakout box I was going to butcher to make my adaptor harness but tracing the pins would have cost alot of time.
dbh97
- Slack: dbh97
I've used Dirtypcbs quite a bit, but I found that this board was big enough that it was cheaper from JLC. At least when I did it; pricing may have changed.
Here are the fab files:
https://github.com/rusefi/rusefi/raw/master/hardware/Breakout_104pin_EEC-V-Connector/export/eecv_gerbers_0.1.zip
turbotrana
Is there anyone who can give me a hand ordering from JLC. I can't even manage to get the Gerberfab files on the order site (yes have no clue about this PCB stuff) and have no clue what to put in the other order details . I have made an account and could PM the log in details.
dbh97
- Slack: dbh97
Hold off for a sec on ordering that, that's actually the old 2-layer files.
dbh97
- Slack: dbh97
@turbotrana OK I've got the PCB updated, this link should get you the right file.
https://github.com/rusefi/rusefi/raw/master/hardware/Breakout_104pin_EEC-V-Connector/export/eecv_gerbers_0.3.zip
Upload that to JLC and it should automatically select 4-layer and the proper board size. I think the only other option you might want to change is if you want a different color. Some colors cost more and take longer.
turbotrana
Thanks heaps
turbotrana
All worked out with the order this time. $56US with $10 promo discount. Once again thanks heaps.
turbotrana
Took 9 days from JLCPCB to Perth Aust. Pretty good service. Fits nicely to plug. Regards
SHOf429
Some connector data from another site.
Female Terminal - F4SB-14487-AA or XL2T-14487-AA - 776235-1 sourced from onlinecomponents.com
ECU Connector End - F5SB-14A624-AA - 770750-1 sourced from onlinecomponents.com minimum order quantity of 6
Harness Connector End - F5SB-14A464-AA - 776557-1 sourced from onlinecomponents.com minimum order quantity of 48 EDIT 2 connectorpeople.com, they have them in stock but have a $25 dollar minimum.
Gasket - 776237-1 - sourced from onlinecomponents.com minimum order quantity of 625
Housing cover - 770768-1 - sourced from onlinecomponents.com
All of the part numbers listed AFTER the Ford numbers are the TE Connectivity numbers (formerly Tyco Electronics). Those should be able to be sourced virtually anywhere.
Josh
94 Ford Taurus SHO
94 Ford Taurus SHO
Cory1015
DO you have any of these for sale? I would like to get one if possible.dbh97 wrote: ↑Tue Jan 26, 2021 10:08 pmBreakouts have arrived. If you want one, let me know.
