Trying to setup ilde and coasting.
1. Looking at vertical scale... "Multiplier" should be "Position" or "Percent" in Coasting IAC for auto-idle?
2. RPM on current screenshoot is 2000. Coasting is green. But IDLE position oscillating between 90 and 70.
I tried to set really low values in this table in case it is Multiplier...
IDLE position is still high. What is used as a base for this Multiplier?
@mck1117 this is your open-in-closed branch...
