Ferrari F136 4.2 seems to be ME7.1.1 like https://rusefi.com/forum/viewtopic.php?f=4&t=1931
but newer F136 4.7 engine is not an ME7.1.1 but something 154 pin. What is it? Did VAG have a port-injected v8 engine/ECU or was it direct injected v8 already?
Ferrari F136 4.7 ECU
Re: Ferrari F136 4.7 ECU
is that a ME17.7.8 like on some Mercedes 12 cylinder for which pinout is not available?
tells us it's a Bosch ME9.1.1
mk e
Ferrari is not now nor was it ever part of VAG. Both companies use Bosch so things often look similar but I don't believe any of it is interchangeable. I'm pretty sure the Ferrari and Maserati ecu versions are also not interchangeable....that is just how they roll.
The port or direct question depends on year I think..... 2009 and newer should be direct...but its ferrari so 2009 could be either or I would assume as they tend to release a new model in limited quantities the final year of the previous model so 2009 was the final year of F430 which is port injected and the first year or the F458 which is direct injected I'm pretty sure. But then what they did for customer engines like Maserati I just don't know, but probably direct in 2010? Just a guess.
Cracken-wakes
This pertains to my interests - subscribed.
(though mine is a 4.2, with a different bosch ecu and loom
Mark
I'm a noob round here - please by nice.
Mark
