Hellen Miata NB1
Hellen Miata NB1
The wait is over and Hellen for NB1 miata is now officially in the works!
https://github.com/rusefi/hellen-NB1-issues
stefanst
Re: Hellen Miata NB1
Post by stefanst »
@andreyB want to come visit and help me drop the drivetrain in the NB1 test mule?
stefanst wrote:
Sat Jun 26, 2021 9:37 pm
Only if German-speaking child labor is permitted.
jmr
Github Username: JimRowan
Post by jmr »
This is good news!
Can you share plans a bit?
Will it have on board WBO2 controller?
I understand the NB2 version has some extra outputs that could in theory drive my 5th injector (ecool -- FFS). Would that be possible here?
Will it have a CAN interface? (FD?)
Inputs for an E85 sensor?
WBO yes.
Probably some extra outputs (boost control, meth, random other hw, etc).
Yes CAN, negative on FD. The value just isn't there, as relatively few chips support it. The processors we use mostly were launched 5-8 years ago.
Yes to flex input! Flex input is the same as a trigger input, actually.
Gerry
Github Username: gerryhernandez
Post by Gerry »
Hey there, I'm new here, but I came for the NB1 support. My drivetrain is intact and I'm ready to be a mule. I'm buying the preassembled ECU from BeerMoney. Once I have it, I'll be more than happy to share whatever logs you guys would like to see. :)
Subscribing to this thread.
BeerMoneyMotorsports
Post by BeerMoneyMotorsports »
Quick update. She is up and running!
