When VNLD5300
Current - Output (Max) 2A
meets a 2OHm solenoid
Hello chip shortage
What is acceleration-type knock sensor?Each cylinder has an acceleration-type knock sensor that, with ECM control, protects the engine from detonation. Within one or two detonating cycles the system pulls ignition timing back to prevent abnormal combustion. The system is an improvement over the previous ion-sensing knock detection.
And looks like it's the second and most serious JLCPCB fabrication issue we've experienced so far A few vias seem to be shorting layers those are not supposed to be shorting.
ID Name Length Data
550 Lowbeam(LOOP) 6 xx 00 00 00 00 00
550 Highbeam 6 xx ** ** ** ** **
550 Clutch Pressed 6 xx ** ** ** ** **
550 Menu/Scroll 8 04 06 00 00 00 B4 00 FF
544 Throttle 8 xx ** ** ** ** ** ** **
542 Jiffystand up 8 xx ** ** ** ** ** ** **
542 Jiffystand down 8 xx ** ** ** ** ** ** **
541 Engine Temp 8 ** ** ** ** ** xx ** **
540 Engine runtime since start 8 ** ** ** ** ** ** xx xx
532 Pin Code 8 ** ** ** ** ** ** ** **
530 Battery voltage 8 ** ** ** ** ** xx ** **
530 Neutral Light 8 ** ** xx ** ** ** ** **
5C1 Clock FF= 12/14H clock 8 SS MM HH ** ** ** ** FF
5C0 Km/miles switch 8 xx ** ** ** ** ** ** **
5C0 Odometer 8 ** ** ** ** ** xx xx xx
521 Speed 7 ** XX ** ** **
520 ABS sensors 5 ** ** ** ** **
7E1 ABS ? ** ** ** ** ** ** ** **
7E9 ABS 2 ? ** ** ** ** ** ** ** **
7E2 BCM ? ** ** ** ** ** ** ** **
7EA BCM 2 ? ** ** ** ** ** ** ** **
7E0 ECU ? ** ** ** ** ** ** ** **
7E8 ECU 2 ? ** ** ** ** ** ** ** **
