PDM info dump
PDM info dump
Everyone loves a good distraction right?
Radlok RL00571-25 https://www.amphenol-industrial.de/en/RL00571-25/5-7mm-Radlok-plug-25mm-orange/p10796 is an alternative to good old 6mm stud
VN7003ALH sounds cool fun fact: today dev board costs $4 while single chip costs $5. A modern replacement for legacy AUIR3313S?
https://digitalcommons.calpoly.edu/eesp/387/ would be a source of inspiration
Re: PDM info dump
Need help: looking for off-the-shelf hardware for positive terminal. We want a flange touching PCB and we want an eyelet outside of the case.
TDG went with everything custom including 11 head m6 internal low profile nut I would prefer to go with simpler stuff.
Let's start with M6 options?
Maybe wurth 7461098
Maybe wurth 7461084
random cool not M6 stuff
RL9057-203-F1
SLPIRBTPSR3
Re: PDM info dump
Re: PDM info dump
Fri May 13, 2022 11:41 pm
Let's KISS and prototype with a brass bolt
A simple screw is actually less simple - a screw through a PCB will creep he fiberglass, making the board thinner, progressively making the connection worse.
blundar
Github Username: blundar
Slack: Dave B.
Re: PDM info dump
Post by blundar »
The VN700x are decent parts. I am using them as a replacement for the marked-for-obsolescence VN5E010AH. I have a couple thousand of them right now because.... I could buy them. Supply is *extremely* limited.
The Weurth terminals are also awesome. They're very well designed. I think I am using a M5 one? Availability is kind of icky sometimes. TME seem to do a very good job of stocking them, if you don't mind shipping from Europe.
blundar
Slack: Dave B.
Re: PDM info dump
Post by blundar »
Another source of high-current lug stuff is lugsdirect.com
They have a lot of bizarre and interesting parts.
I've tried some of their "SMD" parts (i.e. https://lugsdirect.com/B2C-PCB-SS-Surface-mount-tech-2-14AWG-115A-PCB-terminal.htm ) and have found them to be too easy to break off PCBs in the course of securing wires.
The slotted/TH parts (i.e. https://lugsdirect.com/B6A-PCB.htm ) are very good quality. Great value.
Note: these are *hard* to solder with just a regular soldering iron. Even with a 100W professional iron, you need to do some pre-heating. The parts just soak up too much heat. Wave solder with a little pre-heat? Butter. Excellent coating.
Re: PDM info dump
Also older MC33984/MC33988 - dual channel direct or SPI control. AliExpress has them at fairly decent price.
opelpanfan
Github Username: opelpanfan
Slack: Ben
Re: PDM info dump
Post by opelpanfan »
Re: PDM info dump
Re: PDM info dump
Would a latest and greatest VN9008AJTR be cool on a PDM? Pretty available right now.
kneelo
Re: PDM info dump
Post by kneelo »
Sun Feb 19, 2023 5:58 pm
open source design https://github.com/corygrant/DingoPDM_HW
Im looking at getting a run of these assembled to have a play around with... any interest if i get a few extra? Will probably do the standard 8 output and the 4 higher current output 'max' versions.
Not sure on timing as i would prefer to get it with all the smd parts installed and it looks like jlc are out of the bts7002 fets at the moment.
Also not sure on cost yet, but would need to cover postage from my relatively remote part of Australia.
Looks good but Im not involved in this project so dont know how well or even if these work... so check it out yourself and makes sure you know what your getting into.
