Help configuring Trigger inputs.
Can anyone assist me in rectifying this error? trying to find the pin setting for the Critical LED without luck, I need this specified pin for the specific injector.
And the second issue, I need PE0 and PE1 to be my cam inputs and changed the setting in the INI file to enable it's selection but now I get this invalid error can anyone point me to the area in the source where I need to enable these pins also?
Re: Help configuring Trigger inputs.
https://github.com/rusefi/rusefi/tree/master/firmware/config/boards#q-how-do-i-change-primary-uart-pins-via-ts
use https://rusefi.com/build_server/rusefi_bundle_frankenso_na6.zip
overall you are not providing the clear context. look like you have some magic or not magic hardware you are trying to use with rusEFI. by not caring to provide the clear context you are not helping me help you
