I will be borrowing a white miata just to go visit a dyno and show off.
https://github.com/rusefi/rusefi/wiki/Hellen-NB1 has pointed me at https://www.bmotorsports.com/shop/product_info.php/products_id/4462 and we shall figure out the official part number of both shell and terminal (terminal we maybe already know @stefanst?)
I am planning to use a https://www.ebay.com/itm/332125229888 3 METRE ORANGE SILICONE VACUUM HOSE AIR ENGINE BAY DRESS UP 3MM FIT CITROEN
White 96/97 miata
White 96/97 miata
Re: White 96/97 miata
https://rusefi.com/online/view.php?msq=1085
I see internal MAP sensor was not selected by default let me improve that https://github.com/rusefi/rusefi/commit/06f4ee7bf50dd392254a8ee56e6e91f951607be8
What else? Shall I expect the vehicle to just fire up with that tune?
Oh it's a mess
96 boards have NB1 hard-coded as defaults
Progress https://github.com/rusefi/rusefi/commit/983682d11fa72085302e2de9b4a81edb69c7c575 but it's probably still pretty broken
Does anyone has a nice good 96 tune URL?
BeerMoneyMotorsports
As discussed on Slack, https://rusefi.com/online/view.php?msq=1086 should be a solid startup map for 96/97.
Laptop was not working so I only have SD card log. Apparently we have bug with SD card logs https://github.com/rusefi/rusefi/issues/4291 thus REO would not accept that log file
78 inches of hose around the vehicle
Very nice!
Looks like 96 miata oem ECU works based on crank?
Because timing was 25 degrees off. Which might mean that CAS was 25 degrees off, and rusEFI runs off CAS while OEM runs off crank?
https://rusefi.com/online/view.php?msq=1098
fancy dyno pull https://rusefi.com/online/view.php?log=918
