[README] End users, PLEASE subscribe to this topic - MAJOR firmware announcements
Re: End users, PLEASE subscribe to this topic - MAJOR firmware announcements
I would ignore the Hardware: F4 message it could be broken https://github.com/rusefi/rusefi/issues/3973
please open case, please get unit into DFU mode with the hardware buttons if it seems not to respond
also latest snapsshot has relevant improvements please use https://rusefi.com/build_server/rusefi_bundle_proteus_f7.zip file
Attached is the log file with update to the latest daily build.
Result:
-> console doesn't crash anymore
-> no MSC devices (neither internal flash nor SD card)
I have not used the PROG button, there is everything purely via software.
Result:
- updatelog.log
- (55.39 KiB) Downloaded 712 times
I've tried to flash the old firmware version, snapshot_20211114_215906_proteus_f7_rusefi:
1. boot into bootloader (PROG button pressed during power on)
2. full erase (stm32-full-erase.bat)
3. flash the firmware (stm32-flash-dfu.bat)
4. reboot
Neither flash nor SD card in explorer. Device manager says:
Console connects the Proteus. but I get a warning:
Is that normal?
LED status:
-> green on
-> blue is flashing
-> yellow is on
4. reboot
Is that normal?
LED status:
-> green on
-> blue is flashing
-> yellow is on
"flash CRC failed" is expected for first boot after full erase
Behaviour before update:
after connect Proteus to PC I've got two drives in windows explorer:
-> one with rusefi_proteus_f7.ini on it
-> one with log files, my SD card installed in Proteus.
-> COM-Port for communication
After update:
-> no drives, neither SD card nor internal flash with rusefi_proteus_f7.ini
-> COM-Port for communication it there
Is the behaviour after update normal or is something wrong?
After update:
We turned off the "virtual USB drive" on F7 proteus to work around some other issues. You should still see the SD card.
Can you find your ECU in device manager with it set to "view by connection"?
Hint: you can select the com port, then change to "view by connection" mode, and it'll auto expand the view to show the device.
I see this:
I see this:
Okay, that explains it of course.
I see this:
Right click "STMicroelectronics virtual COM port", uninstall, check the "delete driver" box, hit OK. Unplug ECU, replug ECU.
Done:
Thank you Matt, you are my hero!
And the next error, in TunerStudio (Version 3.1.08) during creating of a new project:
Ideas?
Ideas?
After upgrading to the latest daily build (snapshot_20220303_003810_proteus_f7_rusefi), things are looking good now, even in TunerStudio.
Thanks Matt and Andrey for the quick help, you guys are awesome!
We have a new release https://github.com/rusefi/rusefi/releases/tag/20220317.release
New top level menu 'view' now shows a lot, a LOT of sweet data!
No documentation as always and still a lot to do but a huge step forward in terms of monitoring
https://github.com/rusefi/rusefi/issues/3614
We have a release candidate https://github.com/rusefi/rusefi/releases/tag/20220422_release
rusEFI snapshot has an incompatible change to calibration format, please plan your bump to snapshot accordingly.
We have a release candidate https://github.com/rusefi/rusefi/releases/tag/20220602_release
We have a release candidate https://github.com/rusefi/rusefi/releases/tag/20220702_release
There is now a way to lock your tune from reading! https://github.com/rusefi/rusefi/issues/4243
I shall teach people how to unlock on the need-to-know-basis (evil laughter)
Fresh release candidate https://github.com/rusefi/rusefi/releases/tag/20220812_release
Release candidate https://github.com/rusefi/rusefi/releases/tag/20220914_release contains important fix of https://github.com/rusefi/rusefi/issues/4557 which we probably have since end of June.
Release candidate https://github.com/rusefi/rusefi/releases/tag/20221117_release
We would need a new release due to nasty https://github.com/rusefi/rusefi/issues/4826
Release candidate https://github.com/rusefi/rusefi/releases/tag/20221201_release
And third time a release candidate https://github.com/rusefi/rusefi/releases/tag/20221209_release
Just promoted https://github.com/rusefi/rusefi/releases/tag/20230203_release to latest releaseAndreyB wrote: ↑Sun Feb 05, 2023 2:21 amNew RC https://github.com/rusefi/rusefi/releases/tag/20230203_release
David has implemented Nightly for https://github.com/rusefi/rusefi/releases
Open question to update documentation to explain what exactly does it mean https://github.com/rusefi/rusefi_documentation/issues/427
Just promoted https://github.com/rusefi/rusefi/releases/tag/20230419_release to release status
