Throttle body BOSCH 0 280 750 474 have problem TPS
It's all about the code!
Hmelik
Post by Hmelik »
Re: Throttle body BOSCH 0 280 750 474 have problem TPS
Try changing calibration number just a bit manually. Looks like usually error is below threshold but sometimes it gets out of expected range :(
one useful tool is to look at the raw primary vs. secondary in megalogviewer - it looks like you're overtraveling the sensor slightly
try:
set your primary min/max to 0.664/4.340
set your secondary min/max to 4.365/0.671
Hmelik
Post by Hmelik »
https://www.rusefi.com/online/view.php?log=1141
beter but not work
playing and 108/868 882/134 work
