[README] End users, PLEASE subscribe to this topic - MAJOR firmware announcements
Re: End users, PLEASE subscribe to this topic - MAJOR firmware announcements
Just promoted to release.AndreyB wrote: ↑Mon Jun 05, 2023 4:22 amNew RC https://github.com/rusefi/rusefi/releases/tag/release_230604
*BREAKING CHANGE* https://github.com/rusefi/rusefi/issues/5353 changes injector firing order in batch mode if "Individually wired Batch Fuel" setting was not selected. "Individually wired Batch Fuel" setting is actually removed altogether, it's now always "Individually wired Batch Fuel".
Something is going on with F7 version of the firmware (which usually means Proteus F7 but 4chan F7 is also coming soon)
I've seen three different hanging scenarios. One I am pretty sure was below-average stack allocation on a specific thread - this one was taken care under https://github.com/rusefi/rusefi/issues/5320
https://github.com/rusefi/rusefi/issues/5354 is still an issue
And finally this has caused smoke yesterday
https://github.com/rusefi/rusefi/issues/5426
@dron_gus has fixed that issue above see https://rusefi.com/forum/viewtopic.php?p=48114#p48114 for technical details
July release candidate https://github.com/rusefi/rusefi/releases/tag/20230726_release
tmbryhn
Downloaded latest release candidate. Can't open console because of what appears to be outdated Java version.
Follows link that automatically opens: https://www.java.com/en/download/
Link takes me to "Version 8 Update 381". This does not appear to be "11".
Download, install and restart. Same error.
Any tips or link to correct download?
tmbryhn
mi-hol
- Github Username: mi-hol
I would strongly advise to switch to an open-source JAVA distribution due to ORACLE changing their license to be non-free some time ago.
Recommended is a version with long-time support (LTS)
https://adoptium.net/download/
Best Regards
Michael
Benelli Tornado 900 Tre
Benelli TNT 1130 (rebuilding)
Michael
Nice catch thank you! Will create a new RC now.
July RC 2nd attempt with better JRE link
https://github.com/rusefi/rusefi/releases/tag/20230726_2_release
latest release has a nasty defect https://github.com/rusefi/rusefi/issues/5542
A work-around would be to set Controller->"HPFP Cam Configuration" -> "Number of lobes" to zero
Release candidate https://github.com/rusefi/rusefi/releases/tag/release_20231007
Release candidate https://github.com/rusefi/rusefi/releases/tag/release_240101
zed65
I tried to compile the 240101 firmware but got an error:
What am I doing wrong?
Definitely posting on a wrong forum thread - end users do not compile
Also using wrong compiler probably see https://github.com/rusefi/rusefi/issues/5644
New release candidate https://github.com/rusefi/rusefi/releases/tag/release_20240227
Nope, that one did not go well - still defects related to the build scrips modernization.AndreyB wrote: ↑Wed Feb 28, 2024 12:19 amNew release candidate https://github.com/rusefi/rusefi/releases/tag/release_20240227
Let's try again - new release candidate https://github.com/rusefi/rusefi/releases/tag/release_20240304
New release candidate https://github.com/rusefi/rusefi/releases/tag/release_20240418
https://github.com/rusefi/rusefi/issues/6349 is the most important bugfix of the last couple of years, hopefully that addresses https://github.com/rusefi/rusefi/issues/5728 and https://github.com/rusefi/rusefi/issues/5729
Has been a while, new RC https://github.com/rusefi/rusefi/releases/tag/release_20240809
release candidate https://github.com/rusefi/rusefi/releases/tag/release_20241113
In latest development we've improved error handling
* on the one hand hard faults are now resetting, not hanging with red LED
* on the other hand, we now write error reports to SD card
* next step https://github.com/rusefi/rusefi/issues/7291
- mpgmike
Clicked on the above link, found near the bottom the rusefi_bundle_UAEFI.zip. Tried loading it:
Console version 20250424
Windows 10 10.0
Bundle BundleInfo{branchName='master', target='uaefi'}
Suspending port scanning...
Port scanning is suspended.
Connecting to port `COM9`...
Performing action on port COM9...
Received a signature rusEFI master.2024.11.17.uaefi.2834573262
Page size is 22960
Reading current calibrations...
Backing up current ini-file `C:\Users\mpgMike\.rusEFI\ini_database\2834573262.ini`...
`2834573262.ini` ini-file is backed up as `state/2025-32-29-01.32.44_prev_calibrations.ini`
Backing up calibrations to files `state/2025-32-29-01.32.44_prev_calibrations.zip` and `state/2025-32-29-01.32.44_prev_calibrations.msq`...
Calibrations are backed up to files `state/2025-32-29-01.32.44_prev_calibrations.zip` and `state/2025-32-29-01.32.44_prev_calibrations.msq`
Resuming port scanning...
Port scanning is resumed.
Using selected COM9
Reboot command [reboot_openblt] sent into serial=COM9!
Waiting for ECU on port COM9 (ECU w/ BL) to reboot to OpenBlt for up to 60 seconds....
Waiting for new OpenBlt port to appear.........
Serial port COM10 appeared, programming firmware...
flashSerial ..\._rusefi_update.srec
Phase: Load firmware file
Error: java.lang.RuntimeException: BltFirmwareLoadFromFile() not OK, failed to load firmware file.
Phase: Cleanup
hint: error state is already in your clipboard, please use PASTE or Ctrl-V while reporting issues
I can't even get the engine to start now. Point me in a direction to figure this out please.
Windows 10 10.0
Page size is 22960
Using selected COM9
Phase: Cleanup
Just migrated to latest ChibiOS 21.11 - that's major update, theoretically all kinds of things could go wrong. My vehicle runs like before, what about yours?
has been a while so here it comes https://github.com/rusefi/rusefi/releases/tag/release_20251017
