No knock signal on 2nd and 5th cylinder
The problem arose after the update. The cylinders are assigned to the correct inputs and even if they are swapped the problem does not disappear. Tried to reduce KnockSampling.
At first I thought that the problem was in the wiring, but when I changed
signal 1 to cylinder 2
signal 2 to cylinder 1
I saw that there was still no signal in the 2nd.
Here is what I see in the logs
Here are links to tune and logs
Tune is https://rusefi.com/online/view.php?msq=1535
Logs is https://rusefi.com/online/view.php?log=1277
Missing knock signal for some cylinders on Proteus 0.7
WOOL
WOOL
Re: Missing knock signal for some cylinders on Proteus 0.7
I looked at REonline the same Hardware as I have, I found a Mercedes on proteu_f4
and the situation is similar. In 25 seconds, he accumulated 10K knocks.
https://rusefi.com/online/view.php?log=1213
only he has a situation on the 5th and 6th cylinders on the contrary. If I don't have a cam triger defined, is it not related to the prouses in the definition of knocking?
WOOL
Now I have assembled an ardu-stim on the atmel and set a set of triggers 4-1 and 1 for the cam. Connected Crank and Cam and set up RE for 4-1 trigger and 1 cam signal and received individual ignition and all 6 cylinders received their signals. I understand this problem is somehow related to synchronization. I am attaching the log
Log https://rusefi.com/online/view.php?log=1280
one day someone should improve https://github.com/rusefi/rusefi/issues/5561
WOOL
