uaEFI Ultra Affordable EFI
Re: uaEFI Ultra Affordable EFI
Now waiting for wideband cables and pigtails to be manufactured.
ykill
Good job! Pretty interesting at this price!
jevgienij
Optional EGR or EGT?
EGT, thank you for pointing out the typo!
it has passed testing https://github.com/rusefi/uaefi/issues/25 and it's now up for sale at https://www.shop.rusefi.com/shop/universal-control-unit
joaodh
I'm currently following various topics on the forum, and I'm contemplating converting my classic car to run on an ignition-controlled ECU.
Initially, I'll stick with the stock injection system (K-Jet
My goal is to maintain the original look of the engine bay, so I plan to adapt the distributor with a trigger wheel.
Is this board suitable for use? I'm not a fan of the connector positions, for me will be better to have all pins on the same side. I might explore changing that.
Thanks for this fantastic project.
uaEFI is doing good! There is already one unofficial adapter see FB group. We've just merged preview of the official hellen-one module for uaEFI adapters see https://github.com/andreika-git/hellen-one/tree/master/modules/uaefi/
Chybber
Hello I've made a simple box/case and lid with snap fit. It's real simple but should work ok
The board is fastend in with 4 m3 screws directly in the plastic And the lid is as mentioned snap fit, good tight fit so should not come loose.
I've only test printed in petg so I don't know if pla etc would work ( you have to test)
My print settings were
0.16 layer height
3 walls
6 top/bottom layers
0.16 layer height
3 walls
6 top/bottom layers
Now working on first official adapter board so rev B had changes specifically for ease of adapter application
Kim has posted another enclosure on FB - https://www.thingiverse.com/thing:6498664
Mappie
- Github Username: EDMaus
Hi,
2 question 's :
Q1, what is the purpose of the Optional Can 2? or better, when would i need it? any example?
Q2, i recieved my JDY-33 bluetooth, can i just solder it in? or does it need programming first?
thank you.
2 question 's :
thank you.
Q1: I do not know. What's the purpose of CAN 1 or even what's the purpose of rusEFI?
Q2: just updated https://github.com/rusefi/rusefi/wiki/Bluetooth with references to recently updated tickets about all that
Random suggestion while unfortunatelly things are not perfect
gurov
- Github Username: ggurov
- Slack: ggurov
- Contact:
more mounting suggestions:
carrier board in a stock ECU case
able to close the cover:
pins into UAEFI molex connectors at almost straight angles:
for molex spacing, 3 pin connectors with middle pin removed:
Atlantis2013
hello,
what is the copper weight for inner and outer ? both 1oz ?
best regards
best regards
probably, whatever is the default.Atlantis2013 wrote: ↑Tue Apr 30, 2024 11:10 amwhat is the copper weight for inner and outer ? both 1oz ?
Atlantis2013
default is 1oz for outter and 0.5 for innerAndreyB wrote: ↑Tue Apr 30, 2024 2:21 pmprobably, whatever is the default.Atlantis2013 wrote: ↑Tue Apr 30, 2024 11:10 amwhat is the copper weight for inner and outer ? both 1oz ?
Larspars
- Github Username: larsnergard
Hi
What componets do I need to populate CAN2 option? Cant find it in any BOM.
ludowrx974
I'm really sorry for this question, I'm a beginner. I was able to see the different documents on the UAEFI. Concerning the VR conditioner, is it able to work well with the civic (or dizzy) igniter?
yes search gives https://rusefi.com/forum/viewtopic.php?p=49552#p49552ludowrx974 wrote: ↑Thu Jul 18, 2024 11:37 amI'm really sorry for this question, I'm a beginner. I was able to see the different documents on the UAEFI. Concerning the VR conditioner, is it able to work well with the civic (or dizzy) igniter?
A nice enclosure https://github.com/Light-r4y/uaEFI_case
- mpgmike
Looks like it works with the standard UAEFI (not the 121). Are they for sale for those of us who still don't have a 3-D printer? If so, how much?
- mpgmike
AndreyB, the current UAEFI uses a TI SN74LVC4245APWR Logic Translator for U103. It is capable of sourcing and sinking 24 mA on the outputs. Spent some time and found a pin-compatible TI SN74LXCH8T245PWR capable of source/sink at 50 mA. I bring this up because I fried U103 twice trying to drive LS coils. Mouser single unit price for what you're using is $1.04, while the suggested replacement is slightly higher at $1.73. Here is a link to the data sheet: https://www.ti.com/lit/ds/symlink/sn74lxch8t245.pdf?ts=1743163518629&ref_url=https%253A%252F%252Fwww.mouser.com%252F
- mpgmike
Out of curiosity I bench tested an LS coil logic circuit. I connected both grounds, but not battery voltage. Applying 5 volts to the signal drew less than 2 mA. I have no idea why LS coils burned up U103 two times.
Great news!
https://github.com/rusefi/uaefi/issues/78 and noted on https://github.com/andreika-git/hellen-one/issues/378#issuecomment-2764559502
Nice video
n6b044vr4
Does uaEFI support the Idle stepper without any modifications?
The description says it can, but looking at the circuit and circuit board, I can't find any suitable driver chips. They are present on the circuit in DC_MOTOR_0.1 and 0.2, but are missing from the main PCB. Do I need to make boards for them separately? Where will they need to be connected in this case?
I'm just starting to study the rusEfi project, so a lot of things seem unclear to me.
Please clarify what gives you the confidence to make this incorrect statement?
