Hellen-One example Problem
Bruno Ferreira
Github Username: ECU-tech
Post by Bruno Ferreira »
Sorry I'm asking for help, but I don't understand much about this and I'm trying to understand how to make an ECU. I'm having this error and I don't see why.
Re: Hellen-One example Problem
Please try removing dashes from file name and report if that has helped.
If that did not help please try removing underscores symbol from file name and report if that has helped.
Bruno Ferreira
Another problem, it is no longer the same. I'm almost there...
Bruno Ferreira
Thanks AndreyB for the help. I managed to get to the end without any problems. Now I have to understand the PCB and schematic issues regarding components and pinouts. If you have time to take a look at my Github (ECU-tech) and give your opinion, I'd appreciate it... But anyway, thank you for everything and keep up the good work. ;)
